tachometer install
Old Feb 13, 2008 | 01:26 PM
mav87's Avatar
Default tachometer install
call me retarded but how do u install a tach in a 96 honda civ 5 spd 1.6 liter.
Old Feb 13, 2008 | 01:28 PM
mini-meEj1's Avatar
Default Re: tachometer install (mav87)
you should try searching next time it will save you alot of headach
https://honda-tech.com/zerothread?id=949918
Old Feb 13, 2008 | 01:33 PM
mav87's Avatar
Default Re: tachometer install (mini-meEj1)
i did [racial pejorative]
Old Feb 14, 2008 | 07:31 PM
mini-meEj1's Avatar
i was just tryin to help. you should of just been a stain on the expletiveing sheets! and if you were half way intelligent you would think to yourself "hey maybe i should check out the FAQ in the forum" but no you couldn't even do that you expletiveing nOOb!
Old Feb 14, 2008 | 07:35 PM
ek-g6's Avatar
http://www.hoon.tk/tech_tips/tacho.html
heres another enjoi!
Old Feb 14, 2008 | 07:43 PM
97Ej6mike's Avatar
lol, had to.
Hook the tach up to a power source, such as your 12v cig adapter, and the signal wire goes to the blue wire (spliced) behind the cluster on the main plug.
DC_RaceR
Sep 8, 2006 04:24 PM
ironchef25
16
Aug 26, 2004 06:55 PM
fatboyslim44
May 3, 2004 05:25 PM
Secret Squirrel
Oct 26, 2002 05:52 PM
MetalKill
May 5, 2002 06:21 AM
