Bent valves?
Old Feb 13, 2008 | 10:41 AM
Itu's Avatar
Itu
Default Bent valves?
Ok guys, I need some help. I live out in the sticks, so I had my 89 honda civic taken to the local garage, because I thought that I was having issues with my starter. This is not a garage that regulary works on Hondas.
My husband had left the lights on and killed the battery. I replaced the battery and it still wouldn't start. When I turned the key, the started would start spinning, but wouldn't turn the engine over. It would just spin the starter. I just spoke to the mechanic who said that the starter, flywheel, and timing belt are fine. He said that it acts like there is no compression. He has that he can get the engine to start by adding air and that usually something like this would point towards bent valves, but he's checked and the valves seem to be just fine. He's stumped, but said that he's going to keep trying to figure it out. Anyone have any suggestions?
Old Feb 13, 2008 | 10:45 AM
Red_ED8's Avatar
Default Re: Bent valves? (Itu)
Maybe he needs to double check that starter. That sounds like the teeth on the starter are stripped and is just spinnig away. Just my 2 cents.
Old Feb 13, 2008 | 11:03 AM
c0d0r's Avatar
yeah, sounds like the starter drive pinion gear isnt reaching out to contact the flywheel.
Old Feb 13, 2008 | 11:36 AM
mar778c's Avatar
Community Builder
Community Influencer
I vote starter. Just tell him to change the starter.
Emmanuel2112
Oct 2, 2009 12:44 PM
Touge Tuning
May 3, 2006 11:14 AM
Fobstylez
Dec 26, 2005 08:26 PM
gen3hatch
Sep 14, 2003 01:22 PM
ls_vtec_b18a1
Nov 4, 2002 07:12 PM
