gap between pressure plate and flywheel?
Old Feb 13, 2008 | 09:52 AM
turkeyslow's Avatar
Default gap between pressure plate and flywheel?
hey i just did a clutch in my d16z6 and when i was tightening my tranny back up to the engine i noticed this
the red is the dowl pin
the green is the gap
the yellow is the bolt
i tightened the bolts that go from the pressure plate to the flywheel to honda specs then noticed there was still about a 1/8 inch gap between the pressure plate and flywheel but im not sure if its supposed to be like that or if i gotta pull the tranny and tighten them up further?
thanks in advance mangs
Old Feb 13, 2008 | 09:55 AM
JDM EJ2's Avatar
Default Re: gap between pressure plate and flywheel? (turkeyslow)
Make sure you have everything lined up right, if you do, then your fine, but if its out of alignment, you can really screw up the clutch. Take it apart, check it twice, then put it back together.
Old Feb 13, 2008 | 10:04 AM
turkeyslow's Avatar
when you say have everything lined up do you mean all the dowl pins around the pressure plate or the slines that go into the crank?
Old Feb 13, 2008 | 10:18 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (turkeyslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turkeyslow &raquo;</TD></TR><TR><TD CLASS="quote">when you say have everything lined up do you mean all the dowl pins around the pressure plate or the slines that go into the crank?</TD></TR></TABLE>
Both. Use a clutch alignment tool for the splines. Make sure that all the dowel pins go into their respective locations. The pressure plate only fits in ONE orientation onto the flywheel.
95_red_dc
Transmission & Drivetrain
Sep 5, 2008 02:38 AM
95_red_dc
Sep 2, 2008 06:19 PM
cmasonrun
Jun 10, 2007 04:44 PM
boosted350z
Nov 27, 2004 06:49 AM
