FS: JDM B16 lsd complete swap
Old Feb 13, 2008 | 06:39 AM
klungemonger's Avatar
Default FS: JDM B16 lsd complete swap
I am contemplating going H22 so just seeing if there's any interest in this swap I have. I have not even installed this motor since I bought it from Japan Motor Import last year. This is basically a complete swap for 96-00 Civics. Here's what's included:
JDM B16A complete longblock (170hp stock)
JDM factory LSD transmission
NEW! AEBS Typhoon intake manifold
NEW! AEBS 65mm throttle body, port-matched to i/m, inlet tapered
NEW! 8lb aluminum flywheel
NEW! TCS 6-puck sprung hub clutch good to 400hp
Distributor
midshaft & axles
alternator
Mugen knock-off valve cover (blue)
NGK plug wires
shift linkage & mount brackets for all 96-00 Civics (including CRV a/c bracket to maintain your stock compressor)
Phearable.net B16 basemap chip (ecu not included)
distributor, injectors, alternator are all OBD2 now. Those can easily be changed if you want it for 95-earlier models. Only needs an exhaust manifold or header.
This swap with LSD costs $2550 + shipping from Hmotors, and you are getting all the EK mounts, OBD2 stuff, and $700 in extra new parts already installed. So $2500 firm In Michigan, pickup preferred or shipment can be arranged.
blindsk8er1013
Dec 5, 2007 01:12 PM
jdmegcivic95
Jun 20, 2006 10:45 AM
Robstunner4
Aug 12, 2004 08:17 PM
