ok NEW PROBLEM can anyone help? car is hesitating 95 civic
ok i had the issue where the fuse kept blowing to my fuel pump, i had a bran new fuel pump assembly installed and i picked the car up today. The car ran amazing felt so much bettter until i guess it warmed up. as soon as i got about a mile or two, to my apartment, i slowed down for speed bumps and the car decides to start missing TERRIBLY. acting like it did right before the fuse blew before. the fuse didnt blow and shut off this time it just misses terribly and acts like it wants to shut off so i drove it as fast as i could and parked it in front of my apartment. now this issue decided to come up after =car was stolen and my ignition was busted..it almost seems it could be as simple as a fuel filter? any suggestions at all..this is pissing me off thanks
when was last time u replace fuel filter. also check on your spark plugs and wires.and check on your fuel injectors. cause i had the same problem before.the car hesitated and ran like a subaru.turned out one of the injectors was shot. pm me if u have any more problem.
im not sure the last time the fuel filter was changed the shitty thing is im not driving this car to the store lol i cant afford for it to break down again. damit i wish i could pin point this
u dont really have to take it to store before u can find out whats wrong with the car. store charges too much for simple work.
and what engine do u have under 95 civic hood? i forgot to ask this
d16z6 i found a part of the wiring harness melted together i guess the crooks who stole it let it drop onto something hot so in this case the only way to fix problem is to buy a bran new harness, theres no parts that disconnect? no way to ghetto rig?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenpovver »</TD></TR><TR><TD CLASS="quote">d16z6 i found a part of the wiring harness melted together i guess the crooks who stole it let it drop onto something hot so in this case the only way to fix problem is to buy a bran new harness, theres no parts that disconnect? no way to ghetto rig?</TD></TR></TABLE>
if u can take some pics.that would help
i just had a similiar problem. my problem was actually the ground wires. things people suggested to me were, spark plugs, spark plug wires, firing sequence, timing, dizzy, dizzy cap, coil and rotor button. also check your injectors. gl
punkracer
Apr 2, 2005 07:32 AM
