Cooling system problems......
Old Feb 12, 2008 | 10:58 PM
garageEF's Avatar
Default Cooling system problems......
im having some issues with burning coolant somehow. the problem started about a month ago, i started my car one morning and it ran sluggish for a minute and puffed out white smoke. it has been blowing white smoke on and off since then and tonight the idle started to fluctuate(low coolant). it never overheats and doesn't blow smoke constantly but im starting to worry.
Old Feb 13, 2008 | 01:20 AM
kamakazejack's Avatar
Default Re: Cooling system problems...... (garageEF)
sounds like a head gasket
Old Feb 13, 2008 | 07:09 AM
alscrx's Avatar
Default Re: Cooling system problems...... (kamakazejack)
yeah sounds like a head gasket to me too....
keep and eye on the temp gauge. If you run it hot it can warp the head.
Old Feb 13, 2008 | 08:41 AM
LSVTEC96HB's Avatar
Default Re: Cooling system problems...... (alscrx)
yeah, the head gaskets on the EFs were made of cardboard. I've had many many EFs and its a common problem. get the head checked for warpage, and put it back together with a HG for a 92-up D series. Now's a good time to get the valve stem seals replaced and get a valve job done. Or just do a swap. Good luck!
Old Feb 13, 2008 | 02:16 PM
garageEF's Avatar
Default Re: Cooling system problems...... (LSVTEC96HB)
well i just checked for coolant in the oil and couldnt find any mixing. i did notice that the oil level has dropped and this motor has never burned or leaked a drop of oil. its a SOHC ZC BTW.
Old Feb 14, 2008 | 01:01 PM
garageEF's Avatar
c'mon people need some input im goin out to work on it soon.
Old Feb 14, 2008 | 07:35 PM
run the car with rad cap off, bubbling in the coolant is a good indication head gasket is gone or going EDIT: wouldnt hurt to get the rad pressure tested
derek18105
11
Nov 25, 2012 04:19 PM
Spooon
May 23, 2012 08:47 AM
2001tegy
Sep 12, 2009 01:00 PM
95civic16
Jul 24, 2007 11:09 AM
EF9 JAMS!!!
Aug 7, 2006 05:18 PM
