Suspension & Brakes Theory, alignment, spring rates....
eg lower control arms on ek?
Old Feb 12, 2008 | 09:20 PM
hatch is best's Avatar
Default eg lower control arms on ek?
Could the eg or dc lower rear control arm with struts fit on an ek?
Old Feb 12, 2008 | 11:16 PM
BlueIntegraBoy's Avatar
Default Re: eg lower control arms on ek? (hatch is best)
Nope, the EG/DC LCAs are too short
Old Feb 13, 2008 | 05:12 AM
Default Re: eg lower control arms on ek? (BlueIntegraBoy)
No anyway at all it can work?
Reason I am asking because I am getting a good deal on some zeals coilovers
Old Feb 13, 2008 | 07:23 AM
drhonda's Avatar
You have to change out the cross member for it to work, but it can be done.
Old Feb 13, 2008 | 07:37 AM
Default Re: (drhonda)
Its the rear LCA I am asking about
Old Feb 13, 2008 | 08:44 AM
what gsr's Avatar
Default Re: (hatch is best)
I think that if you buy function 7 lcas they make itr spec ones for ek.
Old Feb 13, 2008 | 11:47 AM
user 98292739's Avatar
no
ek arms are longer and much thinner
Old Jan 2, 2021 | 11:26 AM
YashR1's Avatar
Are the rear sub frames interchangeable? Bolts on?
Old Jan 3, 2021 | 08:42 AM
spAdam's Avatar
Loved
Community Favorite
Cut & weld. You'll need a skilled body shop to swap the subframes. Replacing the subframe will cost somewhere between $500-$1000 + parts (I had to replace mine last year due to damage). I've never actually seen anyone do the swap, so you'd be on your own to see if it actually fits correctly. Get an Integra Type R subframe if you go that route, then you will no longer need a subframe brace to run a large rear bar.
This is what you actually want though:
View this post on Instagram
Old Jan 3, 2021 | 09:44 AM
TrackSol's Avatar
Wow, holy necro post batman!
2008 -> 2021
Old Jan 3, 2021 | 12:26 PM
spAdam's Avatar
Loved
Community Favorite
Agreed. Figured a pic of Katman’s new control arms would be a nice way to close it out.
at least people are searching first 🤷🏻‍♂️
Old Jan 4, 2021 | 08:09 PM
YashR1's Avatar
https://www.instagram.com/p/CHPMyMNH..._web_copy_link
That seems to be complicated.
My situation is as such:.
I own a Honda EH9 S.I. which has met with an accident. Had a set of new Kido shocks with is safe after the accident. I bought a 96 EK3 and wanted to swap rear discs and shocks to it.
But the issue is that the SI uses ball not folk type shocks. Now i tried using the swapping to test the lower height controling part of the rear shocks with one a yellow shock and it fits. I don't know if D2 uses same kind of fitting to swap as I am getting a deal D2 folk fittings.
Reading comments above and other threads, if i am able to swap the lower part from ball to folk; adding washers to each sides, i should be able to fit the shocks from the EH9 to the EK3.
Old Jan 4, 2021 | 09:58 PM
spAdam's Avatar
Loved
Community Favorite
Yeah that totally works if you can just swap the bottoms from eyes to forks. The arms posted above are also an easy option if you can't swap bottoms.
I wouldn't suggest swapping a subframe unless scrapping the car is the only other option, i.e. it's cracked/torn. It's not that bad of a job in reality, but you need to know what you're doing because it's important that it's done correctly. There were a couple dozen spot welds and some seam sealer and paint required:
Vi3tsi06
Suspension & Brakes
28
Sep 9, 2010 10:05 PM
BrianFreels
May 4, 2009 01:36 PM
JuanK20
Suspension & Brakes
Apr 25, 2006 08:50 PM
R6Elmo
Aug 19, 2003 01:24 PM
paulzy
Apr 12, 2003 01:23 AM
