intake mani wire up
i cant seem to be able to hook my wiring up to my jdm d15b motor obd1 everything seems to be fine but my car is throwin codes and running irradically, here are some pictures, any help is greatly appreciated... if i cant solve it here/now im gonna have to take it somewhere which i really dont wanna do...
Thats your evap purge solenoid, you need to find the wiring to it. It has to be some were, what codes are you throwing? Also I think the tps and map sensor connectors are the same you might have them flipped around.
i gotta find that wire and i cant find it haha, the other mani that came off the motor i bought didnt even have a fitting and i dont know where the 3rd hose (top) goes to or from... i tried flipping those wires back and forth and i got similar results this last time i got a code 7 and code 9 i think... i gotta recheck tho code 7 for sure
ok ill make sure i have those hoses hooked up, youve been great so far thanks. when i was lookin for other hoses to hook up to that sensor i couldnt find anything for it. idk why the "new" mani doesnt have that while the d16 mani has a fitting for it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Thats your evap purge solenoid, you need to find the wiring to it. It has to be some were, what codes are you throwing? Also I think the tps and map sensor connectors are the same you might have them flipped around.</TD></TR></TABLE>
oh, and there are 3 fittings, bottom to vacuum source, top to canister... theres one in between them as well as a plug...
MY EM1 HAS BEEN MOLESTED AND RAPED, NOW ITS IN THERAPHY AND GETTING WIRE TUCKED-SHAVE-REBUILD-NA-D16
jdmboss
Appearance Build Threads
10
Jun 4, 2008 02:35 PM
NAlover
11
Aug 30, 2006 03:44 PM
