wrong clutch?
Old Feb 12, 2008 | 07:06 PM
shizkabob3421's Avatar
Default wrong clutch?
ok my friend gave me an oem clutch he had in his 91 hatch for about a mounth (d15b2)..then i put it in my 92 civic hatch (d15b7) and one was cable trans and mine is hydrolic..so the clutch is really soft and slipping if i get on it and it catches way at the top..was it the wrong clutch i put in?
thanks in advance!
Old Feb 12, 2008 | 08:12 PM
EG2Driver's Avatar
Default Re: wrong clutch? (shizkabob3421)
you can adjust the height at which it catches. There is a bolt that you undo on the master cylinder rod and you can adjust how much the piston will move. Check that out.
Old Feb 12, 2008 | 08:58 PM
Default Re: wrong clutch? (EG2Driver)
ok thanks i will try that tommrow..but is doesnt matter that the clutch is from the 91 hatch.
Modified by shizkabob3421 at 11:12 PM 2/12/2008
Old Feb 13, 2008 | 05:04 AM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 &raquo;</TD></TR><TR><TD CLASS="quote">but is doesnt matter that the clutch is from the 91 hatch.
Modified by shizkabob3421 at 11:12 PM 2/12/2008</TD></TR></TABLE>
Can someone confirm that? I personally don't know, im a B-series kinda guy.
Old Feb 13, 2008 | 09:02 AM
ooo ok then..can andybody?
Old Feb 13, 2008 | 04:12 PM
anybody else have an answer?
Old Feb 15, 2008 | 11:20 AM
tried to adjust it but it still does the same thing slips when its under pressure.
Old Feb 15, 2008 | 12:35 PM
steerh67's Avatar
why don't you look up the clutches for both cars and see if the part numbers are the same
JTR_HATCH_EG
Jan 4, 2013 09:57 PM
therealzk
Dec 12, 2007 04:56 PM
ramz7887
Aug 8, 2003 12:07 PM
Kalokohan
Feb 5, 2002 03:56 PM
