99-00 si header on 92-95 eg
Hi,
I would like to buy an ebay header and almost all the sellers have a cheap header for 99-00 SI b16 series , but they do not specify if it fits on 92-95 eg civics with b16 motors.I think that it fits on the block but maybe not up to the cat.Thanks in advance.
You think will pass fine near the oil pan ?
Here is the buyer that i would like to buy from,maybe you could enter and tell me if it fits.
http://cgi.ebay.com/ebaymotors...83421
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznboyhoy »</TD></TR><TR><TD CLASS="quote">It'll fit perfect. You may have to push the cat up a tad bit.</TD></TR></TABLE>
what ?
did u or have you ever done this before? read what people say above.
do u know dc2,dc4,ITR and 99-00 civic si headers will all bolt on but they have different down pipes' length and flange angles?
what ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cioli »</TD></TR><TR><TD CLASS="quote">@crazyguy,that what i'm thinking at,too.
But maybe i could modify it a little to fit the cat.
if u have d series cat converter.it will be 2 inch short for b series header down pipe to bolt on. u either use b series cat converter or bring it to a muffler shop to have them cut and weld for u. i have been through this a lot and have seen and taught too many people been through this too
i think u will know better of what i am talking about when u bolt on the b series header and then go from there.
the pic shown below is just 94~01 integra. see the down pipe length differnces and flange angles?
I bought a Strup Header off of eBay for the same application and it fit perfectly, so perfect that it bolted straight up to the cat. I lucked out.
So the header should pass fine under the oil pan wich is fine.I have a sport cat from tenzoR and i don't know how the header will fit,but hey i can modify the header to fit the cat,that's not a big problem.
Thanks guys for the help,i will order it as soon as the buyer will answer me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ2 »</TD></TR><TR><TD CLASS="quote">I bought a Strup Header off of eBay for the same application and it fit perfectly, so perfect that it bolted straight up to the cat. I lucked out.</TD></TR></TABLE>'
hmm that header idea sounds pretty familiar
If the header is a true direct bolt-on for the 99-00 Civic Si THEN IT WILL BE A DIRECT FIT FOR AN EG WITH A B16A SWAP provided you also currently have a stock B16A exhaust manifold and stock EG catalytic convertor.
How do I know this?
I have interchanged the 99-00 Si convertor with the DX/Si 92-95 Civic convertors on many occasions, and my wife's 1992 Si hatch had a B16A2 swap with a 99-00 Civic Si DC 4-2-1 header and stock 99-00 Si convertor, with a cat-back Tanabe exhaust made for the stock 92-95 DX/Si hatch - 100% bolt-on!!!
How do I know this?
jdmbseries20
Aug 20, 2005 12:20 PM
whitemike1644
Jun 10, 2003 10:45 PM
