b20 vtec spark plugs, wires.. what should i use?
Old Feb 11, 2008 | 10:30 PM
desii's Avatar
Default b20 vtec spark plugs, wires.. what should i use?
well my car has a b20b vtec with a b16a head.. i think its time for a tune up but im a little confused on what parts to use.. when i got the swap done the shop told me to for the bottom end buy b20 parts for top end buy b16 parts..
i just wanted to double check and see what brands i should get or if theyre any suggestions ( i did a quick search but didnt find exactly what i was looking for )
what distributor cap and rotor should i buy? for a civic si, or honda crv?
what spark plugs, and wires should i buy too? should i just get oem quality or next one up??
and i was reading up on the spark plug gap, should i do it at .44?
the cars a 1997 civic ex, b20bvtec b16a head stock interals with arp rods and new bearings...(if it makes a difference in the parts i should be buying)
any other suggestions for stuff i should be changing, swap has 1500 miles on it, the plugs looked bad and the shop told me to do a tune up with in my next oil change so im doing it a bit early...
thanks!
also any one know anything about these clear distributor caps? these seem pretty cool lol
http://pa.partsandaccessories....=true
Old Feb 21, 2008 | 05:17 AM
smugmug89's Avatar
Default Re: b20 vtec spark plugs, wires.. what should i use? (desii)
You should use B16 plugs, wires and distributor on the head, preffered NGK plugs. (99-00 Civic Si).And what you get for the bottom end depends on your setup. Like if you ran GSr pumps and belt or what not. And those distributor caps wont affect anything. They're just for looks.
Maximus
Jun 2, 2019 09:18 PM
excoupeb20jdm
Honda CR-V & Element
Mar 20, 2018 07:56 AM
jonyi27
May 17, 2014 06:04 AM
expressivepinoyboy
Apr 26, 2011 04:16 PM
konidude
Feb 25, 2006 10:22 AM
