big problem..need all the help i can get...
well i finished swapping in a 99 gsr swap into my 94 eg hatch..everything went great..all mounts are good and tight all hoses good..wired up..perfect..axles in put back my suspension..but now there a problem..wen i go over 10 mph the front end of the car starts shaking violently ..like if the lug nuts were really loose..but there not..i cant seem to figure out the problem..i switched out the axles ..still no luck..can something have happedn during the swap to the inside of the tranny that would cause this? please need this fixed asap..thanks
If the car was moved with no axles in it the wheel bearing may be separating, Like he said check the axle nut. You may have ruined a wheel bearing.
make sure u tighten that nut with the cotter pin on the Camber arm thing on top of the spindle.....That ***** happens a lot. just a thought cuz i've seen wheels wobble side to side while driving cuz of this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_n_FlipFlops »</TD></TR><TR><TD CLASS="quote">maybe unbalance tires? bubble?</TD></TR></TABLE>a really big bubble for 10mph.
do you feel the shaking through the wheel? pedals? linkage? dash? everything? just shaking could be lots of things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared »</TD></TR><TR><TD CLASS="quote">a really big bubble for 10mph.
do you feel the shaking through the wheel? pedals? linkage? dash? everything? just shaking could be lots of things.</TD></TR></TABLE>...
