Suspension & Brakes Theory, alignment, spring rates....
Eiback sportline / neuspeed race
Old Feb 11, 2008 | 08:59 PM
Meoshe's Avatar
Default Eiback sportline / neuspeed race
I'm deciding between the eibach sportlines and neuspeed race. I will have a 14mm rear sway with the stock front on a 98 civic ex. I like the rates of the neuspeed but i'm worried about the drop being too drastic. Also thinking of making diy top hats. Anyone with experience with either springs chime in.
Edit: I will be road racing BUT on a budget. I don't need height adjustment that's why i decided on springs. I was browsing and might just have to opt for the koni yellows. Would those handle the 2.25 drop well or are top hats still in order.
Modified by Meoshe at 4:01 AM 2/12/2008
Modified by Meoshe at 4:02 AM 2/12/2008
Old Feb 12, 2008 | 07:56 AM
EK_B's Avatar
Springs are a joke to Koni Yellows.
If you want to risk bottoming out, go with the Sportlines.
Old Feb 12, 2008 | 01:25 PM
Meoshe's Avatar
So maybe the konis are overkill...... The AGX's should be more than enough? I guess if it has too much roll I'll beef up the sways.
Old Feb 13, 2008 | 08:57 AM
EK_B's Avatar
The Yellows are a good buy, don't get that confused, they will last longer than most if not all shocks out there. It's the budget that is the major factor.
Old Feb 13, 2008 | 02:14 PM
Meoshe's Avatar
Yeah.... I still need tires, a new helmet since they changed the ratings, and fees still need to be paid.
Old Feb 15, 2008 | 06:45 PM
Meoshe's Avatar
I've been reading a lot and I'm even more confused. I saw some posts saying that getting a mild spring ( which would be not as low) with thicker sway bars would be good for track. The main thing is hoping the fender liner doesn't rub or scraping the front on bounce. Does anyone here Track their car with springs or does everyone use coilovers.
Old Feb 16, 2008 | 10:04 PM
Dave_Dc2's Avatar
Default Re: Eiback sportline / neuspeed race (Meoshe)
Ya the sprotlines are diesigned to be alittle high in the front..u wouldnt have to worry about bottoming out with the sportlines..but then again the neuspeeds will give it a cleaner drop
96b18c-r
Suspension & Brakes
Mar 13, 2009 03:25 AM
verycleanhatch
Suspension & Brakes
Oct 10, 2007 03:07 PM
Aar99GSR
Mar 22, 2002 05:28 AM
vpforeva
Jun 1, 2001 11:12 PM
