B16/D16 axle interchangeability
Old Feb 11, 2008 | 08:45 PM
xx4GIVENxx's Avatar
Default B16/D16 axle interchangeability
Hello, fella's,
I'm kind of a noob to the Honda game, so I have a question. I'm currently changing the axles on my '94 Del Sol SI (SOHC V-tec, D16, MT, etc.). Will the axles from a V-tec model (DOHC B16) bolt onto the SI? Any help will be greatly appreciated.
Thank you.
Old Feb 11, 2008 | 08:46 PM
BlueIntegraBoy's Avatar
Default Re: B16/D16 axle interchangeability (xx4GIVENxx)
No, it won't. You need d-series axles from a 92-00 Civic.
Old Feb 11, 2008 | 08:47 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx4GIVENxx &raquo;</TD></TR><TR><TD CLASS="quote">Hello, fella's,
Thank you.</TD></TR></TABLE>
Nope, the B series engines utilize an intermediate shaft, whole different setup, however you can use any D series axles I believe...
Old Feb 12, 2008 | 09:23 AM
xx4GIVENxx's Avatar
Default Re: B16/D16 axle interchangeability (saywhat)
OK, I got the driver's side squared away, but I have to ask (told you I'm a newbie). The B16 axle (passenger's side) does not have an intermediate shaft, and neither does the one I removed from my car (D16). Are they still not compatible (does the fitment issue go beyond the intermediate shaft problem)?
The reason I ask is that I have a reman B16 RH axle lying around still in the box, so I'd like to avoid shelling out $60 if I can use this axle.
Thank you for your patience.
Old Feb 12, 2008 | 09:28 AM
crazyguy's Avatar
nope.they are totally different.
Purple_Hatch
Dec 8, 2016 10:22 AM
dohc_87hatch
Nov 12, 2009 10:01 AM
=ITRpoweredEK9=
Dec 21, 2005 10:17 AM
Sound Streamin'
Oct 23, 2004 06:11 PM
ham
Sep 4, 2004 11:14 AM
