Part number / where to buy input shaft bearing?
Old Feb 11, 2008 | 08:03 PM
DuronClocker's Avatar
Default Part number / where to buy input shaft bearing?
D16Z6/B000 S20 tranny. Need to put a clutch in the car and have the noise everyone describes as the input shaft bearing going out, so I figure now is the best time to do it.
Anyone have the part number or where I can buy it?
Is it a Timken #207, or is that a different bearing?
Old Feb 11, 2008 | 08:46 PM
BlueIntegraBoy's Avatar
Default Re: Part number / where to buy input shaft bearing? (DuronClocker)
91002-PS0-003 BEARING, BALL (6305SPL) $19.08
http://www.slhondaparts.com
Old Feb 11, 2008 | 09:43 PM
Default Re: Part number / where to buy input shaft bearing? (BlueIntegraBoy)
Cool, thanks for the reply. The only info I was able to find was a slightly different number, but now that I have this one, I'm finding it all over, lol
Old Feb 12, 2008 | 11:27 AM
blk92_d16's Avatar
While you have the trans out, do the axle seals and get the ISB seal as well...I just got a "kit" from Bone with all the above for $44 shipped.
Old Feb 12, 2008 | 11:39 AM
marcs1337's Avatar
make sure its the shaft bearing, i had a similar problem in my del sol, sounded like input shaft bearing, turned out to be wheel bearing
Old Feb 14, 2008 | 04:29 PM
Yeah, I picked up the seals as well. Noise is most noticeable in neutral with the clutch out, even when not moving. Push the clutch in, noise goes away. My first guess would be the throw out bearing, but everywhere I've read on here, that seems to be an ISB issue. Definitely not an axle/wheel bearing issue.
Either way, it was only ~$50 parts, and I'm already going to be doing the clutch, so I figured it'd be nice to get it done anyways.
Thefinder808
13
Nov 5, 2013 06:29 AM
AddictedToBoost
Feb 25, 2012 07:58 PM
Pbanto
Apr 8, 2009 05:07 AM
pinky5
Nov 12, 2007 04:10 AM
