Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Adjustable Proportioning Valves
Old Feb 11, 2008 | 07:13 PM
rdssk8rcs1's Avatar
Default Adjustable Proportioning Valves
Looking for thoughts and recomendations on these. Thank you in advance
Old Feb 11, 2008 | 09:13 PM
rdssk8rcs1's Avatar
Default Re: Adjustable Proportioning Valves (rdssk8rcs1)
any thoughts?
Old Feb 12, 2008 | 11:51 AM
Ekasey's Avatar
Ap Racing
Tilton
Old Feb 12, 2008 | 04:57 PM
rdssk8rcs1's Avatar
Default Re: Adjustable Proportioning Valves (Ekasey)
Haver you had any expirience with either?
Old Feb 12, 2008 | 06:15 PM
EleanoR's Avatar
<------- using a Tilton Prop Valve
We can adjust brake bias from front to rear. Our car is so light on the rear end that we were locking up the rear and the car was 'darting' under hard braking even with a non-aggressive alignment setting. Once the prop valve was installed this cleared up the issue and the car started to brake phenomenally. BTW, it's an EG with Type R brakes full built race car - 230whp. We have to be able to stop it properly.
If i had to do it all over again I would re-use the same Tilton valve. It is a quality piece and most tend to use it in my neck of the woods.
Old Feb 12, 2008 | 09:09 PM
Ekasey's Avatar
what kind of experience?
it's a pretty simple mechanical part
Old Feb 12, 2008 | 10:39 PM
Justin Jones's Avatar
I don't mean to thread hi-jack or anything, but could someone post pictures of their installed adjustable proportioning valve?
Thanks.
Old Feb 13, 2008 | 09:05 AM
rallyeman's Avatar
Default Re: Adjustable Proportioning Valves (EleanoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">&lt;------- using a Tilton Prop Valve
If i had to do it all over again I would re-use the same Tilton valve. It is a quality piece and most tend to use it in my neck of the woods. </TD></TR></TABLE>
Tilton..But Which one??
Is it easy to install?
Old Feb 13, 2008 | 12:10 PM
nscirocco's Avatar
Default Re: Adjustable Proportioning Valves (rallyeman)
i'm using a metric tilton, but the standard one would have probably been easier to make fittings/flares for .. when i do it again (which i have to because the stupid thing keeps jamming) i'll get a 2 channel ap-racing one but it's alot more expensive..
wilwood also makes one
Old Feb 13, 2008 | 06:56 PM
rdssk8rcs1's Avatar
What size inlets and outlets should i be looking for?
Old Feb 14, 2008 | 07:14 AM
nscirocco's Avatar
just get the standard one .. 3/16" inverted flare
Old Feb 14, 2008 | 02:48 PM
Johnny Mac's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekasey &raquo;</TD></TR><TR><TD CLASS="quote">what kind of experience?
it's a pretty simple mechanical part</TD></TR></TABLE>
His first race car to be is on jackstands, what more experience do you need?
SoCal EJ1
Suspension & Brakes
Oct 31, 2008 07:38 PM
951BRO
36
Jun 14, 2007 08:38 PM
SneezinCD5
Jun 2, 2007 02:41 AM
coneheadsracing
17
Jan 23, 2006 06:34 PM
crexer
10
Apr 17, 2004 09:13 PM
