Cooling fans always going on after parking the car?!
Old Feb 11, 2008 | 06:55 PM
A Tribe Called Honda's Avatar
Default Cooling fans always going on after parking the car?!
So this is kinda random, but all of a sudden my 1994 Accord EX with 182k is having the cooling fans turn on when I turn off the car and park it. I've seen this happen in the summer a few times when it gets super hot. But it is winter now and around 40 degrees F. Even after a few miles of easy driving with just the defrost going, the fans still seem to always kick in after I park the car. Coolant level is fine and temp guage is normal. This just came outta nowhere...Any suggestions?
Old Feb 11, 2008 | 07:23 PM
hondadude's Avatar
Default Re: Cooling fans always going on after parking the car?! (A Tribe Called Honda)
When the fans are running after a short drive and the key is off, open the hood and follow the top radiator hose back to the head; you'll see the temp sensor, in the pipe fitting.
Unplug it.
If the fans shut off you have found the problem
Old Feb 12, 2008 | 12:37 PM
Default Re: Cooling fans always going on after parking the car?! (hondadude)
Thanks hondadude. I'll give that a try tonight. If that is the case, I just need a new temperature sensor, right?
Old Feb 12, 2008 | 05:26 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">When the fans are running after a short drive and the key is off, open the hood and follow the top radiator hose back to the head; you'll see the temp sensor, in the pipe fitting.
Unplug it.
If the fans shut off you have found the problem</TD></TR></TABLE>
This happened to me once, and one time only. I was more concerned about why the sensor would be reading anything if the ignition is off, could you elaborate on that?
Old Feb 13, 2008 | 06:02 PM
hondadude's Avatar
Default Re: Cooling fans always going on after parking the car?! (awdgsx96)
That sensor is there to protect the head from hot soak temps.
If the engine is at peak temp and the engine is shut off; yes, you are not creating any more heat; however the temp can rise from all the heat stored in the block/head.
That sensor is connected thru a fan timer unit that starts counting down when the key is turned off,yet can trip the relay if the sensor calls out HOT HOT HOT
The fans can cycle any time in the 15 minutes of the timer count down.
Old Feb 15, 2008 | 03:50 PM
hondatuningboi96's Avatar
ok how about this i'm having the same problem but when i unplug mines it continues to run could that be a relay or something else.
Old Feb 15, 2008 | 05:11 PM
loup05's Avatar
Default Re: Cooling fans always going on after parking the car?! (hondatuningboi96)
wait i thought it was normal for the fansto comeon after the car is off?
Old Feb 15, 2008 | 07:23 PM
Default Re: Cooling fans always going on after parking the car?! (loup05)
it is when u turn the car off about minute later they kick on but after i turn my key off they keep goin and won't stop
Old Feb 15, 2008 | 09:27 PM
loup05's Avatar
hmm mine come on and off after i take off the key for a few minutes.. so urs stay on and dont stop?
Old Feb 16, 2008 | 07:12 AM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">That sensor is there to protect the head from hot soak temps.
The fans can cycle any time in the 15 minutes of the timer count down.</TD></TR></TABLE>
Thanks for the info
Old Feb 16, 2008 | 08:00 AM
they sure do
holmesnmanny
Apr 5, 2009 12:14 AM
supermotothud
Dec 19, 2008 01:38 AM
coolusername
Aug 10, 2007 03:52 AM
pa2play
Aug 10, 2004 06:16 AM
