EM1 headunit install. Help me out.
Old Feb 11, 2008 | 04:25 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default EM1 headunit install. Help me out.
I have a 99 Si. I'm not quite sure what to search for since I'm not quite sure if it's an issue or not. I'm about to install a headunit into my EM1. My friend did this...and for some reason lost his keyless entry. I've heard SOMEWHERE that the keyless is connected to the back of the radio...so to leave the stock radio tucked behind the console along with the aftermarket radio.
Anyone wanna shed some light on this?
Old Feb 11, 2008 | 04:46 PM
Frickr's Avatar
Default Re: EM1 headunit install. Help me out. (B serious)
i think in 99 they changed it over to where the keyless control box is located in the driverside kickpanel. on my 00, it was a direct swap.
Old Feb 11, 2008 | 04:47 PM
pdiggitydogg's Avatar
Correct^
The keyless and dome light control is only in the radio for 96-98 Civics. Dont worry about it.
Old Feb 11, 2008 | 04:56 PM
stock99si's Avatar
i swapped it out after someone else swapped it out on my 99, still worked fine.
Old Feb 11, 2008 | 06:14 PM
B serious's Avatar
freaking awesome. thanks guys!
Old Feb 11, 2008 | 06:30 PM
Frickr's Avatar
Default Re: (B serious)
one thing i think you have to do, is to screw the pocket under the radio in so that it doesnt move.
Old Feb 11, 2008 | 06:41 PM
B serious's Avatar
Default Re: (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">one thing i think you have to do, is to screw the pocket under the radio in so that it doesnt move. </TD></TR></TABLE>
pics?
Old Feb 11, 2008 | 06:52 PM
Frickr's Avatar
ill see what i can do tomorrow, ill have to pull it all out to show you. my cars stuck right n ow so i gotta pull it out before anything
Old Feb 11, 2008 | 06:54 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">ill see what i can do tomorrow, ill have to pull it all out to show you. my cars stuck right n ow so i gotta pull it out before anything</TD></TR></TABLE>
lol dont worry about it. I dont want you to have to take the car apart or anything. Do you mean the lower din pocket? I bought an install kit for like 12 bucks. Did you just screw yours into the existing stock bracket or something?
Old Feb 11, 2008 | 06:56 PM
Frickr's Avatar
yeah, i didnt buy a mounting kit at all, my cd player screwed into the stock place, and had to stick a screw on each side on the bottom of the pocket to hold it in place.
Old Feb 11, 2008 | 07:24 PM
Poppins324's Avatar
if you buy the right kit you shouldnt need to screw the pocket in at all. the kit should bolt in from the side of just pop in if you are cage mounting it.
Old Feb 11, 2008 | 07:53 PM
B serious's Avatar
Default Re: (Poppins324)
yeah I dont think I'm gonna use this kit. It deletes the lower din pocket. Less compartments?! Surely, they jest.
hypnoticustoms
Apr 18, 2007 08:53 PM
WARCOVENANT
Jan 5, 2006 05:21 AM
sp00led
Audio / Security / Video
May 26, 2004 06:21 PM
punx5997
Jan 28, 2004 11:49 AM
