door panel removal(searched)
Old Feb 11, 2008 | 03:22 PM
92egSnatch's Avatar
Default door panel removal(searched)
i need to take the door panel off my 92 vx but cant figure out how to take the
"hand crank" to roll the windows down can anyone help ?
Old Feb 11, 2008 | 03:31 PM
overspooled's Avatar
Default Re: door panel removal(searched) (01D17a1)
theres a little c clip behindthe handle that you have to remove. its a piain in the a$$. push on your door panel a little bit so you have a gap in between the window crank and door panel then you take a flat head srcew driver and push the c clip out. carefull and dont lose it. it should be a gold color. good luck
Old Feb 11, 2008 | 03:32 PM
ifIexplode's Avatar
Behind the handle there is a C clip type thing. . Just pop that off and the handle will slide off. I ussaly use a skinny flat head screw driver.
Maybe another tool will work better for you.
Edit: Overspooled beat me to it.
Old Feb 11, 2008 | 03:36 PM
92egSnatch's Avatar
thanks for the help guys hopefully i can get it off and try and fix my door lock
Old Feb 11, 2008 | 03:40 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (01D17a1)
I fvckin hate that clip. I usually use a piece of sturdy wire that's hooked at one end to get it out.
Old Feb 11, 2008 | 03:43 PM
Crx Jimmy's Avatar
Default Re: (mcvtec)
Use a rag and pull it between the panel and the handle and it should grab the clip and you just pull down, Works for me . Or buy the tool at the parts store for this its like $10
Old Mar 1, 2008 | 04:10 PM
96gsr4door's Avatar
buy the tool
integracura
Dec 17, 2007 02:06 PM
turbob16ef
Oct 4, 2005 02:55 PM
JDMEK206
Jun 27, 2003 02:36 AM
babyviper97
Jan 10, 2003 05:14 AM
serious
Sep 6, 2002 04:40 PM
