Sway Bar won't fit.
Old Jul 3, 2002 | 05:48 PM
ichibano's Avatar
Default Sway Bar won't fit.
I just got an itr sway bar; when I went to put it on my 2000 Civic EX, I noticed that the endlinks have no place to attach on the LCA. Do I need new LCA's or different endlinks? If you have pics of a sway bar and endlinks, please post them.
Old Jul 3, 2002 | 06:23 PM
Greg L's Avatar
Default Re: Sway Bar won't fit. (ichibano)
wut endlinks do u have? U'll need the 99-00 Si Rear Endlinks to get it to werk. The Rear LCA's on all 96-00 civics have holoes in them for sway bars. Hope i could help.
EDIT: Oh ****, are u talkin bout the front or the rear? If the front, just buy 99-00 Si front LCAs, damper forks, and sway bar assembly
[Modified by , 10:24 PM 7/3/2002]
[Modified by , 10:25 PM 7/3/2002]
Old Jul 3, 2002 | 07:03 PM
ichibano's Avatar
Default Re: Sway Bar won't fit. (:hammer:)
It's the rear bar. I think I have the itr endlinks, sholud I just drill new holes in the LCA's? Alson do I need a bracket or spacer to put betwwen the D-bracket and subframe. Thanks in advance.
Old Jul 3, 2002 | 07:21 PM
Greg L's Avatar
do u have holes in the LCAs now? If so just pick up sum Si endlinks, i got mine for $85, ive got the beaks srk which reinforces the subfame, check it out www.beaksproducts.com
Old Jul 4, 2002 | 10:09 AM
ichibano's Avatar
anyone else have any ideas? I think I'm going to use the itr endlinks and drill new holes in the lca's.
Old Jul 5, 2002 | 07:52 AM
cre18's Avatar
here are some very good pics of the BEAKS KIT sway bar from tonyxcom.
should help you to see where everything goes, good luck
https://honda-tech.com/zerothread?id=158241
Old Jul 5, 2002 | 07:54 AM
BROOD's Avatar
No don't drill new holes.....get the correct endlinks. Civic 99-2000 Si endlinks.
[Modified by SLPR, 8:54 AM 7/5/2002]
B20EF
Jul 9, 2008 04:44 AM
giomfe
Suspension & Brakes
Aug 10, 2007 09:36 AM
Shaguar47
Feb 25, 2007 05:16 PM
Amuse9
Dec 30, 2002 12:48 PM
KINgJ8
Sep 4, 2002 05:28 PM
