Calculate max tire width on a wheel
Old Feb 11, 2008 | 02:42 PM
YipMan_Style's Avatar
Default Calculate max tire width on a wheel
I know there is a formula or a general rule on how wide of a tire we can put on a wheel. Does anyone recall the formula?
Of if you could answer the question, maybe I can figure it out.
How wide of a tire can I fit on a 5" wide wheel?
Old Feb 11, 2008 | 06:36 PM
nonsense's Avatar
Default Re: Calculate max tire width on a wheel (YipMan_Style)
Most tire manufacturers will have a min/max wheel width for a given tire. It's mostly dependent on the tire. For example Hankook doesn't list anything for less than a 5.5" for their Z212. Their 195 tire has a min of 5.5". Probably a 185 would be the widest tire you can dit unless you go with a tall, regular tire (i.e. Hankook has a 205/70-15 that they say fits on a 5" rim)
What the hell wheels do you have that are only 5" wide BTW?
Old Feb 11, 2008 | 09:45 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
vx wheels probably. im in the same dilema.
Old Feb 12, 2008 | 08:06 AM
2nd choice. How wide can I with with 15X6?
Old Feb 12, 2008 | 03:43 PM
nsxtasy's Avatar
H-T Order of Merit
You're trying to decide things backwards. You need to FIRST decide the tire size, THEN decide on the rim width.
Also, the best tire size depends on the car it's going on, not just on the wheel size.
You should really spend some time reading the FAQ topic stickied at the top of this forum. You'll learn a lot.
Whiteintegra
Feb 14, 2008 06:43 PM
SJR
Dec 3, 2004 08:25 AM
hondaguyef
Sep 29, 2004 02:52 AM
sTraNdeD
Jun 10, 2004 11:51 PM
Flux
Mar 5, 2002 07:19 PM
