Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
do coilovers have to be adjusted exactly?
Old Feb 11, 2008 | 11:36 AM
kcari's Avatar
Default do coilovers have to be adjusted exactly?
do they have to be adjusted exactly the same height as one another, for example, is it okay one side is a few mm higher than the other? i've noticed one side is a tight finger drop while the other side is not tight. what can i do to make sure they are exactly alike? or does it not matter?
Old Feb 11, 2008 | 11:54 AM
dmorris05's Avatar
Default Re: do coilovers have to be adjusted exactly? (kcari)
When my tech installed mine he counted the notches and permanent markered them so he knew where to adjust them all to...
Old Feb 11, 2008 | 12:02 PM
daddy's Avatar
i use a tape measure but a caliper would work better imo.
in order to get them perfectly even your gonna need measure carefully. and when your talking about finger gapbs make sure its parked on perfectly even ground and measure carefully
Old Feb 11, 2008 | 12:06 PM
tunerkid7's Avatar
Default Re: do coilovers have to be adjusted exactly? (daddy2be)
i use a tape measure and use my fingers for a rough estimate
Old Feb 11, 2008 | 12:20 PM
1llmatic's Avatar
New User
Default Re: do coilovers have to be adjusted exactly? (tunerkid7)
tape measure works well.
Old Feb 11, 2008 | 12:45 PM
toyomatt84's Avatar
Sanji
When adjusting height on my car, I use measurements according to clearance from the ground to the unibody.
Old Feb 11, 2008 | 06:23 PM
kcari's Avatar
Default Re: do coilovers have to be adjusted exactly? (1llmatic)
is it okay if say one side is a little higher than the other?
Old Feb 11, 2008 | 06:25 PM
01em2's Avatar
it'll look funny.
Old Feb 11, 2008 | 06:33 PM
kcari's Avatar
Default Re: do coilovers have to be adjusted exactly? (01em2)
sorry to clarify, can one side be a mm or cm or something really small (not big enough to notice) larger than the other? I think my shop did not measure it correctly because if i stick a finger on one side of the front it is wrapped tightly, but on the other side the finger fits in perfectly. So the difference is not very significant, but is it enough to blow the tires or cause them to wear out unevenly?
also, how would I measure the rear to make sure its even, without removing the wheels? my rears are tucking so i can't really stick a finger in there...
Old Feb 11, 2008 | 06:44 PM
InanimateCarbonRod's Avatar
Measure from the center of the wheel to the fender.
The 'proper' way to adjust them is to have your car corner weighted. For non-competition applications, just measuring the position of the collars should be fine.
Old Feb 12, 2008 | 05:04 AM
Harlowe's Avatar
Function>Fashion
I've read some people make the driver's side a couple rotations higher, so when the driver is in there its even.
Just jack that side up, and take the wheel off and adjust it. Find out what each rotation for your coilovers is. Mine is like 1/8" per rotation, or something, not really sure.
Gant
Suspension & Brakes
Sep 21, 2011 08:18 AM
thebluecrx
Feb 7, 2011 02:38 PM
spooncivic1
Suspension & Brakes
Apr 8, 2006 11:40 PM
DANgerous
Oct 10, 2004 01:36 PM
Hiro
Oct 27, 2001 05:40 PM
