installing short shifter?
got my self a skunk2 shifter for the hatch any pointers or links too installation i know i juss undo the integra shiftlinkage but what about the shift bushing kit i have where do those go? thanks
you will need some vice-grips to hold on to the flat bolts that are near the end of the removal process
sorry i dont have my helms around right now
you'll see exactly where the bushings go as you start taking stuff off. when i put in my skunk2, i found the bolt that came with it was not long enough, and had to reuse stock one. udder dan dat, the round bushing was a pain in the ***, but it goes in eventually.
that sounds weird.
don't be afraid, you can always put it all back together if you get stuck. if you lube EVERYTHING and take your time, you will be happy with the results. you will have parts left over!
that sounds weird.
oh gawd......that thing was a pain in the ***!!!!
i heard it was a pain also ...
try this link http://jdmfan.com/technical/performa..._shortshifter/
slkleltlclh
Jul 21, 2006 09:44 PM
SlowPokeEg
24
May 19, 2005 10:43 PM
