idle going crazy
Old Feb 10, 2008 | 10:20 PM
slammedz6ef's Avatar
Default idle going crazy
in my d16z6 swap ef my idle surges up and down up and down.....is that a bad idle air control valve? or is it something different
Old Feb 10, 2008 | 11:39 PM
Default Re: idle going crazy (slammedz6ef)
Old Feb 11, 2008 | 12:51 AM
Old Feb 11, 2008 | 01:40 AM
all my vac lines are not leaking/disconnected, my coolant is full and i cant figure it out
Old Feb 11, 2008 | 01:48 AM
gibsanez's Avatar
http://www.ef-honda.com/ben/Badidle.php
You can find things like this in the FAQ
Old Feb 11, 2008 | 01:58 AM
Default Re: idle going crazy (gibsanez)
thanks
Old Feb 11, 2008 | 02:40 AM
anthem714's Avatar
had the same prob. I ended up replacing the idle air control valve, the fuel filter, fuel pump, and ta sensor, but none fixed the loping idle between 800-1800 rpm.
I have been doing tests on the computer itself, and found it may be my wiring harness. Check your IACV for continuity and such. If this responds correctly check your wiring harness and ecu. good luck
Old Feb 11, 2008 | 02:47 AM
Default Re: idle going crazy (anthem714)
thanks yea the wiring harness is fresh and a clean job was done on it by a shop in my town, the ecu is new, i just bought the ecu 2 days ago because ppl were saying that could be the problem
fano
Mar 4, 2011 11:39 AM
SOHCMAN
Sep 15, 2008 12:53 PM
geldingmakr
Aug 4, 2004 09:11 AM
allmotorsi04
May 11, 2004 04:49 PM
