Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor.
Old Feb 10, 2008 | 07:21 PM
Harrold's Avatar
Default Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor.
I just installed a new engine into my car and we used the new throttle body from the new engine. Actually the engine is used. It's a D16Y7 with roughly 171,000 Kms.
Anyways, We got the engine in and everything is all good, Except for the the fact that at Idle the RPM's Bouncing From 1000 - 2000 and back again. It does this over and over and over with no sign of it stopping. Now were fairly certain that it's a bad TPS sensor that came along with the new engine but were not 100% sure.
I've done lots of Searching and Wrote down everything I could find about the TPS. Including the Proper Readings, and such. I just wanna make sure that the TPS is the problem before I go ripping it all apart.
Do I need to Remove the throttle body to get at it? And how exactly Do I Adjust it. I've found info on removing it and checking it but not Adjusting it.
Any info or Suggestions will be greatly appreciated.
Old Feb 10, 2008 | 07:32 PM
Crx_Civic's Avatar
Default Re: Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor. (Harrold)
does it run the same when u unplg it? u can test it pretty easily on the car just use an ohm meter across 2 of the wires( not sure what 2 ) and you should get a reading that changes when u open the throttle make sure theres no opens of high resistence spots im not sure what the specs are for it. u might be able to search 4 that or search potentiometer testing or somethin. ???.....prob sounds more like a bad IAC but u can figure it out.!
Old Feb 10, 2008 | 07:33 PM
wakaranai's Avatar
The first thing I would do is check for vacuum leaks.
Next, I would check the coolant level and that you don't have any air in your coolant system.
And finally, I would adjust the idle. It could be a tad bit too high.
Good luck! BTW, a bad TPS can give you the bouncing idle symptom, but so can these other things.
Old Feb 10, 2008 | 09:14 PM
john94delsol's Avatar
maybe a vac leak.
Old Feb 10, 2008 | 10:19 PM
USDMCIVICHATCH's Avatar
Default Re: Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor. (john94delsol)
do you have a CEL? I would say IACV before TPS though
Old Feb 10, 2008 | 11:04 PM
20civic0000si's Avatar
Default Re: Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor. (USDMCIVICHATCH)
I agree either low coolant level or IAC, I've ran into both of those but never a bad TPS, not saying it can't happen though..
Old Feb 11, 2008 | 02:38 PM
Harrold's Avatar
Default Re: Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor. (20civic0000si)
Thanks for the responses guys.
Just to Answer a couple of questions.
I have no CEL on right now.
We bled the coolant system and Added more afterwards. It is Definitely full.
I haven't tried unplugging the TPS sensor just cause I wasn't sure what plug it actually was until last night.
I'm gonna be tinkering around with it a bit. If I figure out the problem I will post it here. Until then keep the Suggestions comming.
Gwallman31
10
Feb 6, 2013 08:05 AM
dc4_wHORE
Sep 26, 2006 04:34 PM
snouka
Oct 15, 2004 02:02 PM
evo
Apr 29, 2002 06:33 AM
soHybridized
Mar 13, 2002 10:22 AM
