FS/FT 98 hatch b16
TRADED. very happy please delete
Modified by AllMtorEg at 7:09 AM 2/12/2008
Modified by AllMtorEg at 6:11 PM 2/25/2008
Modified by AllMtorEg at 4:46 PM 3/6/2008
Modified by AllMtorEg at 11:59 PM 3/9/2008
Modified by AllMtorEg at 9:13 AM 3/17/2008
2000 si.
132k (timing belt replaced at 125k)
AEM short ram
Fidanza 7.5lb flywheel
Competition Clutches Stage II (six puck, sprung hub)
Eibach Sportlines
DC5 exhaust
Vision CF Mirrors (those ***** were expensive)
Skunk 2 shift ****
Sony Xplod head unit
Pioneer 4 ways all the way around.
more info upon inquiry.
AEM short ram
Eibach Sportlines
DC5 exhaust
Skunk 2 shift ****
I am kinda interested in this car. . . I have a '95 EG it is yellow and has a b16a with matching LSD tranny in it. I am currently in the middle of a bottom to top rebuild on the engine and tranny. The current list of items going into the EG are these. . .
TODA Valve Springs and Retainers
CTR Cams
Unorthodox Racing Cams
CTR N1 crank pulley
PCT pistons
Eagle Rods
ACT Prolite Flywheel
Spec Stage II clutch
OEM Honda Head Rebuild kit
OEM Timing Belt
Cometic Head Gasket OEM spec
A few other things I can't remember right now.
Interior has been in the process of removal.
Corbeau Forza Driver seat, Stock Passenger seat.
Skunk2 Rear upper Tower bar
I have everything except the Brake Master Cylinder to do the rear disc conversion including the rear sway bar off the integra donor. not sure on the size of it.
ITR Steering wheel non-SRS
5 inch tach with shift light
A Boost gauge, car was being setup for turbo, but I changed my mind over that
Volt and Air/fuel gauge
It has a set of rims on it, 10 spokes wrapped in Kumho Ecsta
no name coilovers and springs
One piece projector black housing headlights
I got pics if you are interested, like I said I am toying with the notion right now of switching up projects and the Ek hatch is something that I have been interested in. if you are interested or at least open to a notion of this car let me know
- Alex
CTR Cams
CTR N1 crank pulley
PCT pistons
Eagle Rods
OEM Timing Belt
- Alex
i miss it so much.
