Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Civic headlight probs
Old Feb 10, 2008 | 02:27 PM
USMC MAD HATTER's Avatar
Default 2004 Civic headlight problems
FYI, I did try and do a search before I started this thread. If there is one thing I know, that is to use the search button before asking stupid questions... Now for my stupid my question.
My girlfriend owns a 2004 Civic LX. She has been having problems with the headlight bulbs burning out. First it was the passenger side. Then it was the driver side. Now her passenger side doesn't work again. This time I looked at it, and the bulb is fine. For the heck of it I tried the driver side bulb in it, and it still doesn't work. I checked the fuse, and the relays with no luck. They are both fine. Now I'm thinking it's the ballast. However her brights do work. Are there any kind souls out there that think they could solve this problem? If there are any, I would very, greatly appreciate it.
Modified by USMC MAD HATTER at 3:38 PM 2/10/2008
Old Feb 10, 2008 | 08:32 PM
toyomatt84's Avatar
Sanji
Have you taken a look to see if there's any corrosion on the wiring harness plugs?
Old Feb 11, 2008 | 05:22 AM
fongyz22's Avatar
Default Re: 2004 Civic headlight problems (USMC MAD HATTER)
so we're running HID pnp kit on this thing I'm assuming from the words "ballasts" and "relays"...
Ballast could be bad imo. using my logic skillllz
1.) check relay / check fuse. Check OK.
2.) Check pass bulb ?
3.) tried driver's bulb, doesn't work.
deduction: bad ballast to ignite.
*my other advice for you, these issues with pnp hid kits can be resolved by switching back to your OEM halogen bulbs *
Old Feb 11, 2008 | 06:38 AM
Default Re: 2004 Civic headlight problems (fongyz22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">Have you taken a look to see if there's any corrosion on the wiring harness plugs?</TD></TR></TABLE>
I'll have to check for corrosion. It's just that I live in Wisconsin, and it's about -20°F with the windchill. My hands get to hurting pretty fast. The salt and slush may have caused some by now.(corrosion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongyz22 &raquo;</TD></TR><TR><TD CLASS="quote">so we're running HID pnp kit on this thing I'm assuming from the words "ballasts" and "relays"...
*my other advice for you, these issues with pnp hid kits can be resolved by switching back to your OEM halogen bulbs *</TD></TR></TABLE>
I don't really know much about this, so I will assume if she has stock halogens then there are no ballast's.
Old Feb 11, 2008 | 09:20 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USMC MAD HATTER &raquo;</TD></TR><TR><TD CLASS="quote">
I'll have to check for corrosion. It's just that I live in Wisconsin, and it's about -20°F with the windchill. My hands get to hurting pretty fast. The salt and slush may have caused some by now.(corrosion)</TD></TR></TABLE>
I live in Wisconsin as well, just as a side note. And, yes, the weather recently has been utterly ridiculous.
Old Feb 11, 2008 | 02:09 PM
Default Re: 2004 Civic headlight problems (toyomatt84)
I live in Wisconsin as well, just as a side note. And, yes, the weather recently has been utterly ridiculous.</TD></TR></TABLE>
The weather is a bit ridiculous.
So here's the update. I unplugged the bulb again to inspect the connector. I did not notice any corrosion, but did give it a good scrubbing. I wiggled it around a bit, and still no luck. What are all the components between the switch, and the bulb? I figured it would just be some wire, a fuse, and a relay. So what else is there? By the way, thanks for your help guys. Cheers!
Modified by USMC MAD HATTER at 3:25 PM 2/11/2008
Old Feb 11, 2008 | 02:20 PM
JH4ADay's Avatar
* B A N N E D *
So here's the update. I unplugged the bulb again to inspect the connector. I did not notice any corrosion, but did give it a good scrubbing. I wiggled it around a bit, and still no luck. What are all the components between the switch, and the bulb? I figured it would just be some wire, a fuse, and a relay. So what else is there? By the way, thanks for your help guys. Cheers!</TD></TR></TABLE>
dam boot
Old Feb 11, 2008 | 02:26 PM
Default Re: 2004 Civic headlight problems (JH4ADay)
That's Sergeant boot to you.
Modified by USMC MAD HATTER at 3:54 PM 2/11/2008
Old Feb 11, 2008 | 02:28 PM
JH4ADay's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USMC MAD HATTER &raquo;</TD></TR><TR><TD CLASS="quote">That's Sergeant boot to you.</TD></TR></TABLE>
hahah Still a dam boot... Search and i bet your question will be answered
Telecatster
Dec 17, 2013 06:43 AM
Stealth_Ek9
Jan 16, 2008 11:32 AM
Senbonzakura
Jan 4, 2005 07:48 PM
accord ex
Mar 13, 2003 05:55 PM
