Wont start delsol after seting up, started then died after 10 mins
ok my del sol has been seting up for about 5 months and went out to start it today and of course battery is dead. jumped it and was runing ruff and only going to 3500 rpm pull the car around to air up the tires and after i did that reved up the car again for about 5 secs and the car just died and would not run again.pop the hood and seen that the number 3 injector wires was lunch for a mouse. so fixed that and still will not run.so checked for spark and was none. so put new cap and rotor on and still no go.so check for codes now and its a number 16 which is injector code.go outside and crank on it and pull a plug and there coverd in fuel.ive looked every were i could for more chewed wires and couldnt see any. so my question is the car ran but wouldnt go past 3500 and when i held down the gas for 5 secs and car shut down, is there some kind of fuse i could have blown that would cause the car not to get spark.
yoursupahero09
10
Jan 23, 2007 04:19 AM
