symptoms of a bad thermostat
Old Feb 10, 2008 | 01:02 PM
juzthewy's Avatar
Default symptoms of a bad thermostat
ive searched, but i want a straight-forward answer.
- after the car reaches normal operating temperature, the upper rad hose is warm, while the lower hose is cold.
- idle is higher than what it normally should be (~1500 rpm)
- when i turn on the heat in the car, its not cold, but its less that warm, lukewarm you can say.
i ran the car with the rad cap open to let the bubbles out, but the lower hose doesn't warm up - this leads me to believe that my thermostat has gone bad.
What do u guys think?
Old Feb 10, 2008 | 01:34 PM
juzthewy's Avatar
Default Re: symptoms of a bad thermostat (juzthewy)
lol maybe my question would be answered if 14 views turned into 14 replies lolol thanks guys
Old Feb 10, 2008 | 02:15 PM
The Destroyer's Avatar
Lower rad hose wont get hot, and the fan might not turn on.
Old Feb 10, 2008 | 02:30 PM
EG2Driver's Avatar
Default Re: symptoms of a bad thermostat (The Destroyer)
when my thermo was out, the car would take forever to heat up in the summer and as soon as you turned the heat on (in the car) the gauge needle would go down to cold almost immediately.
dbailey
11
Jan 30, 2020 04:27 AM
dlstech
16
Dec 12, 2012 03:04 AM
93grayeg
Jan 19, 2010 08:41 AM
AK77
Oct 20, 2007 03:52 PM
Ludester
Jan 16, 2004 11:19 AM
