Overheating
Old Oct 20, 2007 | 03:06 PM
AK77's Avatar
Default Overheating
So here's what's going on:
At idle, car overheats - temp continues to rise, thermostat doesn't open because the upper hose is hot and the lower is cold.
Ran car without thermostat, both hoses are hot - so water pump is circulating coolant (I assume)
Checked Thermostat in boiling water, its does open - may be it was stuck.
After checking thermostat, re-installed it, temp still continues to rise at idle, lower hose stays cold. But I took it for a drive, as I drove temp came down to about a little over the mid point. Drove it for about 20 miles. Checked the lower hose, its warm now. Upper one is hotter than the lower one so at least the coolant if flowing and t-stat is opening somewhat. The fan did come on. But once I idle again temp begins to rise.
What do you guys think is going on here?
Old Oct 20, 2007 | 03:52 PM
boostedh22lude1's Avatar
Default Re: Overheating (AK77)
ur upper hose is going to be hotter because the water hasnt gone through the radiator yet, the lower hose should be cooler, have you checked your fans? start there first then if your radiator is circulating i would change the t stat.
dbailey
11
Jan 30, 2020 04:27 AM
90dacarlton
Dec 16, 2012 05:59 PM
dlstech
16
Dec 12, 2012 03:04 AM
4doorpowa
Jan 24, 2011 12:50 PM
xolk88
10
Mar 18, 2010 05:18 AM
