oil light came on?
Old Jul 3, 2002 | 02:52 PM
mikeyz's Avatar
Default oil light came on?
drove to work today, parked the car. Went to go get a bite to eat, and when i restarted my car the oil light came on. Oil level is fine. wire goin to the pressure swich is still connected. Any suggestions?? i dont want to drive with the light. how can i check for oil pressure without a gauge. thanks
Old Jul 3, 2002 | 03:05 PM
Cosworth's Avatar
Default Re: oil light came on? (mikeyz)
car info (model, trim-level, year) would help... unless, we're assuming that you have an ITR.
Old Jul 3, 2002 | 03:07 PM
dustin's Avatar
Default Re: oil light came on? (Cosworth)
ITR owners seldom post in the ITR forum
only non itr owners post in here
Old Jul 3, 2002 | 03:11 PM
Reid's Avatar
Global Moderator
Default Re: oil light came on? (dustin)
"I like to ask you ITR owners because you guys usually give good answers."
I think when people say that, they really mean "You ITR owners are losers who surf h-t all day and as a result I'll get a quick answer."
Also I think some ITR owners don't ask questions here for one of two reasons:
1) They bought the ITR because of the hype and take it to the dealer for any problems they incur (including problems with aftermarket parts).
2) They're too proud to admit that a mighty ITR owner does not know the answer to something.
Old Jul 3, 2002 | 03:24 PM
mikeyz's Avatar
Default Re: oil light came on? (Reid)
i have a 96 itr motor in a 96 civic ex
Old Jul 3, 2002 | 04:22 PM
mikeyz's Avatar
anyone?? besides people complaing about why others that dont have itr's that post here.
Old Jul 3, 2002 | 04:27 PM
Bob#455's Avatar
You're probably better off asking in the hybrid forum... It definitely seems like some sort of wiring problem, and one that an ITR owner will probably never run into. The motor might be the same, but the application isn't.
Old Jul 3, 2002 | 07:06 PM
mingchi96
Guest
Posts: n/a
Default Re: oil light came on? (Bob#455)
doubel check yr the sensor is plugged in, the oil pressure sensor. if it is, it could just be a bad sensor.. or bad wiring.. really no way of telling unless you hook up a oil pressure gauge.
Old Jul 3, 2002 | 08:12 PM
Tommy_Gunns's Avatar
It's funny cause it is true
Gotta get my post count up
Old Jul 3, 2002 | 08:45 PM
GreenR's Avatar
May be the oil pump same thing just happened to me but I was racing at the time. VTEC didn't kick in and I found metal particals in my oil and engine makes a noise the sound of metal hitting metal, SO check your oil pump. open the oil cap to see how much oil is getting to the head
[Modified by GreenR, 5:46 AM 7/4/2002]
Old Jul 3, 2002 | 09:52 PM
erottik-R's Avatar
i have a 96 itr motor...
JDM?
Old Jul 3, 2002 | 10:06 PM
EagleR's Avatar
Default Re: oil light came on? (erottik-R)
That was my question as well....
Old Jul 4, 2002 | 08:58 AM
mikeyz's Avatar
Default Re: oil light came on? (EagleR)
yea its a 96 jdm itr engine. itr's were released in japan in 96. Thanks for the replies folks, ill be checking over the engine today since its a holiday
Old Jul 4, 2002 | 09:01 AM
slowassR's Avatar
there is still oil in your car.. is your vtec working ok?
Old Jul 4, 2002 | 09:24 AM
Cosworth's Avatar
hope you didn't take it the wrong way when I asked for your car info... for obvious reason, it's a good thing we asked. It's gotta me one of your wiring that came undone or somehow shorting out. Sorry, can't tell you the exact problem, 'cuz I don't know much about hybriding...
Old Jul 7, 2002 | 09:03 PM
mikeyz's Avatar
ok had the car checked out today, and there is no oil getting to the pressure switch when the car was turned on for a second or so. Took the oil pump apart and nothing broken? why am i not getting any oil pressure, the pump has some wear on the teeth, would that cause it to not get pressure at all? thanks
Old Jul 7, 2002 | 09:06 PM
uNF$@#!'s Avatar
Cool. All this time i thought i was in the wrong forum. I own a Integra Type Rs
zk11
Oct 21, 2003 06:26 PM
comptechgsr
Jun 25, 2002 11:51 PM
