Throttle Body Gasket is it suppose to fit this way?
Recently just bought gasket for RHD racing TB that came with no gasket
I tried to install the gasket it seems that i doesn't align. Not really familiar with the TB installation but is it suppose to fit this way?
some specs if it helps.
69mm on TB
70mm on gasket
69mm on TB
70mm on gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">And what does it look like when you have it the other way? Like upside down? </TD></TR></TABLE>
sup dude.
btw thanks for the clutch line. finally made it
what you see on the picture is the only closest way that aligns with the bolt pattern.
sup dude.
dude put the gasket on the i/m and then put the t/b on hook up all your sensors and you will be fine that is how it looks. mine looked the same way and work just fine let me know how it works out.
