weird bogging problem
hey i have a 91 4 door lx that has a bogging problem when i am driving the car when it is not worm seems to drive good but then when worm i will push on the gas and it will bogg down then it will jump back up to normall and then right back into bogging i have no idea what its is have never had this problem, the car has no check engine lights replaced the fuel filter, cap and rotor, new spark plugs,and still the same thing the only thing that is wrong is a bad passenger axle but that shouldnt make the car bogg. if anyone has had this problem and fixed it let me know or any suggestions on what it could be would be great thanks.
try seafoaming it!! 1/3 in the oil filler, 1/3 in the fuel tank, and 1/3 in the brake booster hose..itll clean out anything thats clogged and all the carbon build up in the motor..
i changed the cat on my miata because it was doin the same thing and boggin went away.
i got a new clutch and fly wheel for my 98 civic coupe and hasnt bogg
what im saying is there are alot of alternatives to this bogging so i hope this helps you!! good luck dude!
ExedyHF02
Oct 18, 2006 08:56 AM
