swap car wont start
Old Feb 9, 2008 | 10:44 PM
obuhmyuh's Avatar
Default swap car wont start
just swapped in a d15b into my obd1 del sol. everything's hooked up but now it wont start... #1 piston isnt getting a spark and one part of the harness (im holding in a pic below) is not getting power even tho the starter is. i will include pics if it helps...
Old Feb 9, 2008 | 10:57 PM
saywhat's Avatar
Default Re: swap car wont start (d[sick]sTeena)
You will warp your valves if you get that running without a manifold...
Old Feb 9, 2008 | 11:11 PM
obuhmyuh's Avatar
Default Re: swap car wont start (saywhat)
i know i will, but im not gonna hook up everything untill i know im not gona need to pull it again. anyone know anything about this? tomorrow im gonna cut/splice corresponding wires to their exact color by the battery that i know is getting power...
ps im sorry i posted this 3 times my screen was frozen and i hit refresh twice. thanks in advance for any help tho
Old Feb 10, 2008 | 10:50 AM
obuhmyuh's Avatar
ttt
Old Feb 11, 2008 | 12:14 AM
obuhmyuh's Avatar
tt
Old Feb 11, 2008 | 12:46 AM
USDMCIVICHATCH's Avatar
don't cut and splice any wires!
that plug you are holding is for the distributor, if you have no spark you might wanna check that out
Old Feb 11, 2008 | 12:48 AM
user 98292739's Avatar
check your ECU check your fuses...cutting wires you are just asking for trouble.
Old Feb 11, 2008 | 03:22 AM
fin781's Avatar
Default Re: (The Lobster)
CHECK GROUNDS, AND JUST PUT THAT MANIFOLD BACK ON WITH 2 OR 3 BOLTS, UNTIL YOUR READY TO HAVE IT ON FOR GOOD.
Old Feb 11, 2008 | 11:21 AM
obuhmyuh's Avatar
i did check my fuses, how do i check my ecu?
Old Feb 11, 2008 | 02:11 PM
obuhmyuh's Avatar
Default Re: (d[sick]sTeena)
anyone???
Old Feb 11, 2008 | 03:44 PM
blwn95civic's Avatar
i dont believe i see any ground connections on the motor. Ground the motor to the frame on the trans side and the valve cover at least. Seen this happen many times...
Transportjockey
10
Sep 2, 2013 11:31 AM
SeanWard
Feb 10, 2009 01:28 PM
