blinker problem
usually means one of the bulbs on that side is bad or not working. turn on your blinker for that side and check and see if both front and rear are working
girlfriends ek was doing that. the rears checked out ok, but the front right was dimmer than the left. pulled it out smacked it around and had no problem since. Look for either a bulb out, or a bulb that looks 1/2 lit when blinking.
actually....i did,
put my hazards on one night and all 4 were blinking at the same rate....and they all are as bright as each other....its just my left blinker blinks really fast (a lot faster than the right)
i have the new bulbs, just havent put them in yet...hopefully that will solve the problem.
