harness issue on 2000 SI
i recently put a 97 JDM GSR motor and ECU in my 2000 civic SI, i used a obd2a single cam vtec harness on the motor. is the obd2a harness compatible with the stock obd2b interior harness? Car will crank but wont turn over. when turning key to accessory, the check engine light wont turn on nor can i hear the fuel pump turn on.
