96 ek aftermarket hub/horn wire not work
so i got myself a boss hub and a wheel from ebay and im working my way through installing it then i come to a problem.took off the airbag took off the wheel.i took off 2 wires that was attached to the srs spiral cable and took off a single wire that slid off easy.i snipped the 2 wire off that was attached to the spiral cable srs cover thing cuz it wouldnt come off.and now i have 1 single wire with connector and 2 wires snipped.i thought that the single wire was the horn but i guess not.they are all grey wires.can any of u 96-00 civic owners show me where u guys hooked ur horn from?im gonna take pictures of the **** i did and post up ina bit.also i was mad while doing this argued over some bs so i was impatient someone please post how ur horn wire is hooked.appreciate it
You need the horn shoe from a 90 civic or use a old pen end
http://rides.webshots.com/phot...jwenV
Then install your wheel and do your horn like so and you should be set
Horn button
https://honda-tech.com/zerothread?id=1887852
http://rides.webshots.com/album/49459198Cjsfnx
Modified by B16B_coupe at 6:21 PM 2/9/2008
Modified by B16B_coupe at 6:36 PM 2/9/2008
Horn button
cmross13
10
Feb 27, 2010 11:39 AM
lcjarrett
10
Oct 9, 2006 10:33 AM
SuperSi
26
Jun 2, 2006 05:18 PM
