Question about B16A Specs
Old Feb 9, 2008 | 02:05 PM
Papichulo1767's Avatar
Default Question about B16A Specs
1992-1995 JDM Honda Civic SiRII (EG6/EG9)
Displacement: 1595 cc
Compression: 10.4:1
Power: 170 hp (130 kW) @ 7800 rpm & 116 ft·lbf (157 N·m) @ 7300 rpm
Transmission: S4C
JDM B16A SiR2 Hydro 170HP
Engine/Trans/ECU/Axles - $2,800.00
LSD add - $400 DOHC VTEC 4 Cylinder 16 Valve
• Hydraulic Transmission
• Redline: 8200 rpm
• Diplacement: 1595cc
• Torque: 116 lb-ft@7300
• Horse Power: 170hp@7800
• Compression Ratio: 10.4:1
• P30 OBD-1 or OBD-2 ECU equipped.
My question is i found this information and whats bothering me is one says the redline is 8200 RPM , and the other is 7300 RPM
WTF????
Thanks for the help
Old Feb 9, 2008 | 02:22 PM
95ProjectEJ1's Avatar
Default Re: Question about B16A Specs (Papichulo1767)
Max hp is @ 7800
Max tq is @ 7300
Your redline is @ 8200
1988_96hb's Avatar
its saying that the redline is at 8200rpm and the max torque is at 7300rpm
Old Feb 9, 2008 | 02:40 PM
Default Re: Question about B16A Specs (1988_96hb)
Meaning ..... i could take it to around 8200 RPM when shifting and would be normal procedure
Old Feb 9, 2008 | 03:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Papichulo1767 &raquo;</TD></TR><TR><TD CLASS="quote">Meaning ..... i could take it to around 8200 RPM when shifting and would be normal procedure</TD></TR></TABLE>
Redlining a motor isn't really "normal procedure". You could take it up to 8200, but why... because you think other people see it as cool?
There is a reason why it says "max hp". Nothing spectacular is going to happen after 7800 rpm... not with a stock engine and a stock ecu map.
Old Feb 9, 2008 | 03:19 PM
typeoneeg6's Avatar
Default Re: Question about B16A Specs (95ProjectEJ1)
you need to get dynoed so you can see whre it stops making power. but its pretty much right on. 7700-7800 for a stock b16. with some cams you can move it up.
Old Feb 9, 2008 | 06:42 PM
Sr420Det's Avatar
Wow you shift at 8200 rpm so you can land in the sweet spot in the next gear. You shift at 7300-7800 im beting your going to fall out of vtec when shifting to the next gear thats why you take it to redline.
ef-b16sedan
Aug 22, 2010 11:05 PM
joey funk
Jun 19, 2007 02:52 PM
HondaTech101
Dec 13, 2006 06:29 AM
TypeRGhost
Sep 27, 2001 07:33 AM
