Need Help: 99 Civic Ex Rough Idle? Choking
Old Feb 9, 2008 | 01:46 PM
xlasianizelx's Avatar
Default Need Help: 99 Civic Ex Rough Idle? Choking
i have a 99 civic ex stock motor, d16y8, it was running fine untill 2 days after i installed a dc sport headers (some scrapes on the bottom) it started acting up...
the check engine light was on reading a bad o2 sensor...
when it is a cold start, it runs fine, but if i turn it off and restart it... it feels like it is about to die.., it idles a little lower than usual like around 600rpm, and when i drive it, it jerks like pressure building up then fully releasing.... after a couple mins the idle jumps back to normal and it does the same again everytime i turn it off an start it up from a warm start...
any ideas on what i may be.. please let me know.. thanks
i already cleaned my filter, intake arm, and throtle body, the dude from kragen told me it may be a bad o2, or another sensor from the intake arm (which i cleaned also) but it still acts the same...
Old Feb 9, 2008 | 01:51 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: Need Help: 99 Civic Ex Rough Idle? Choking (xlasianizelx)
So you get a check engine light that says its the o2 sensor?
Old Feb 9, 2008 | 02:07 PM
Default Re: Need Help: 99 Civic Ex Rough Idle? Choking (HondamanXxX)
yup
Old Feb 9, 2008 | 02:12 PM
GO GIANTS!
So replace it?
Jwilson173
Jan 20, 2013 09:26 PM
x4and3r1991
May 31, 2012 06:33 PM
92d15b7
Mar 30, 2011 06:01 AM
-__-
31
Aug 7, 2009 07:46 PM
aojtin
Aug 25, 2007 11:49 AM
