Pro 1's in a stock block h22a!
so im planning on doing an h2b build and i will be using skunk2 pro1's, full valvetrain ect. Now i will be using a stock block. Will i have enough compression to get the most of of the pro 1's? If not i was thinking maybe a thinner head gasket could help a little bit. And this will all be on 93 octane.
evidently you are the tuner you tell us.
ill say if you are running a usdm motor you will not have enough compression to utalize those cams to their fullest potential. if you have plans of raising the compression id say go for it. when i talked to skunk2 they told me that if i didnt get the compression closer to 11 i should take it a step down and get the s2s2's. im running the jdm h22 btw.
While I will agree that they would like more compression, they will be fine on the stock jdm block.
There are quite a few dynos of the pro1s on stock blocks laying around. . .
FWIW- I will be running pro1s on my stock block as well
JunIntegra
Sep 18, 2003 04:04 AM
