Bog/misfire above 30% throttle after running 10+ min
Old Feb 9, 2008 | 10:39 AM
01 LudeDude's Avatar
Default Bog/misfire above 30% throttle after running 10+ min
Problem seemed to start out of the blue, but I only drive the car on the weekends, and not every weekend.
I fire it up, idle for a min or 2, then off I go. For the first 10 mins or so, it runs great as it always has. After 10-15 mins of driving, anything above about 30% throttle will cause it to bogg/misfire badly. I can take the revs to redline at 1/4 throttle with no misfire, and idle is unaffected.
I was thinking that I may have a failing fuel pump (walbro 255) that is heating up and losing pressure, not able to sustain flow when I go heavy throttle. It's the only thing that comes to mind. What do you guys think?
Old Feb 9, 2008 | 10:43 AM
Acidcrakker's Avatar
Default Re: Bog/misfire above 30% throttle after running 10+ min (01 LudeDude)
It sounds like its time to run some tests. Check fuel pressure at +30 percent throttal.
Old Feb 9, 2008 | 10:50 AM
98vtec's Avatar
moderator emeritus
measure your closed and WOT TPS voltage.
.45v closed
~4.6v open
make sure you map sensor is getting a 5v power. You should also check the voltage of the map sensor at idle.
Old Feb 9, 2008 | 01:34 PM
8_6 luder's Avatar
Default Re: Bog/misfire above 30% throttle after running 10+ min (98vtec)
how old is your o2 sensor ? I Had a similar problem and it turned out to be a bad o2.
powertoweight
Engine Management and Tuning
11
Sep 29, 2016 08:02 AM
hillbillycivic
Oct 7, 2013 05:03 PM
stevenwest13
15
Jun 17, 2004 03:08 PM
98gsrTEG
Apr 17, 2004 11:12 AM
