how far does my O2 sensor screw in?
Old Feb 9, 2008 | 09:10 AM
HondaHeddie's Avatar
Default how far does my O2 sensor screw in?
are they straight thread? , therefore they go in till the shoulder seats
or are they pipe thread, and only screw in till they are tight (possibly leaving some threads visible?
Old Feb 9, 2008 | 09:17 AM
thesmogman's Avatar
Default Re: how far does my O2 sensor screw in? (HondaHeddie)
Should go to the shoulder. You might need to wirebrush out the hole/bung/threads and use anti-seize lubricant only on the threads
Old Feb 9, 2008 | 09:20 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: how far does my O2 sensor screw in? (thesmogman)
Go to the shoulder. There should be a crush gasket on it like a sparkplug.
Old Feb 9, 2008 | 09:22 AM
SIred91's Avatar
Rainman
Default Re: how far does my O2 sensor screw in? (ILcrxsi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">Go to the shoulder. There should be a crush gasket on it like a sparkplug.</TD></TR></TABLE>
Yup. And use liberal amount of anti seize
Old Feb 9, 2008 | 09:57 AM
thanks guys
I was afraid of that
The threads on my header must have been screwed (haha)
I put a sensor in it and it threaded in but got tight b4 it seated. I was told it should go to the shoulder so I torqued it in.
Now that I am replacing it, I cant get it out.
I have broken one o2 socket on it and it still isnt moving.
I have been soaking it with deep creep for 24hrs and I am going to be driving the car monday, with of without a sensor. I would much prefer it be with a sensor.
what can I try to get this out?
Old Feb 9, 2008 | 10:08 AM
SIred91's Avatar
Rainman
Default Re: (HondaHeddie)
Sounds like you cross threaded it to me.....good luck
Old Feb 9, 2008 | 10:20 AM
Default Re: (SIred91)
yeah I know.
It would be a 1st if I did, but I cant say I didnt.
Anyone have help for removing a possibly Xthreaded o2 sensor?
Old Feb 9, 2008 | 11:39 AM
bagpipe goatee's Avatar
the threads were probably messed up, happens all the time since it gets so hot.
Use an oxy/acetylene torch, with the header/manifold either off the car, or stuff moved around for plenty of room to get to it.
Old Feb 9, 2008 | 01:34 PM
Default Re: (bagpipe goatee)
I got it out!!!!!
I took a nap
then I turned it back in the slightest bit b4 trying. and it came out like exlax
I even had spun it the last bit.
the only bunged threads are at the shoulder, not at the sensor end.
should I buy a tap b4 I stick a sensor back in?
Old Feb 9, 2008 | 02:16 PM
gibsanez's Avatar
I wonder how much an M18 tap would cost
Old Feb 9, 2008 | 02:17 PM
BUT!!!
after swapping the wires
I start to thread the new sensors in and it stops after about 2-3 turns
I guess the header mfgr left some slag in the threads
now to look for a tap, and drive to the store with a hole in my header
such fun
Old Feb 9, 2008 | 02:40 PM
Default Re: (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">I wonder how much an M18 tap would cost </TD></TR></TABLE>
http://www.google.com/products...hl=en
Old Feb 11, 2008 | 05:53 AM
Well I had no local source for that tap so I decided to go ahead with installing the new sensor.
This time it screwed in much easier, it did not tread to the shoulder by hand like a spark plug, but it was not very stiff. I got it to crush the washer w/o undue effort.
I think the new threads in the header needed to be cleaned.
Well, I guess 3 O2 sensors will have them cleaned.
Just curious, will the spark plug thread tools work for this?
Old Feb 11, 2008 | 07:02 AM
s1267712's Avatar
I have a tool that was my dad's. I think it was made by snapon and one end has a thread chaser for spark plug holes and the other end is a thread chaser for o2 sensor bungs. It is really handy, because I had the same problem with the threads on a used DC header I picked up (I had to use a pipe wrench and an acetelyne torch to get it out) and have always chased the threads before putting in a new sensor.
crxfriday13
11
Jul 3, 2006 05:38 PM
Rhythmsnewsn
Jun 15, 2006 08:10 PM
zzzhondazzz
May 4, 2005 04:38 AM
icon_race_eg
14
May 5, 2004 05:49 PM
Toptul_Honda
Nov 6, 2002 08:12 PM
