something that willWould you use these??
http://cgi.ebay.com/ebaymotors...ZWD1V
I saw this full gasket kit with rings included for a b series. This come with every gasket/seal that is needed for my fresh rebuild. The price is right just dont wanna use something that will give me problems in the future.
This is my setup:
95 b18c1
ctr pistons (either stock bore or .5 over)
acl bearings
balanced
si industries valves/springs/retainers
s2s2's
hytech tri-y
Any comments and/or suggestions that will help me from ppl WHO HAVE BUILT A MOTOR FROM GROUND UP will be appreciated, this is my first "rebuild".
Im tryin to reach 200whp btw.
Modified by Sp00nFed EM1 at 8:00 AM 2/9/2008
This is my setup:
95 b18c1
acl bearings
balanced
s2s2's
hytech tri-y
Look in the all motor dyno thread or use the search function for 200+whp builds. You definately won't have any trouble finding information on that subject. I have build one from the ground up and have my build posted in here https://honda-tech.com/zero...ge=12.
Well the good thing about the ACL's is that they're tri-metal like GSR. Bad thing is that one size doesn't always fit all. I mean, if the clearances are within spec then halleluya, but I'd be a little picky with the main and rod bearings.
Also. ARP rod bolts would be good. As well as ARP head studs for a GSR.
IMO The CTR piston is a bit much for a DD but whatever. I didn't see any rings in the add tho. On a side note. My buddy has told me several times that Nippon sells a kit just like the one you showed us but it includes b16 pistons and rings for 200 some odd dollars. I've personally never seen it tho.
That kit does look good tho. Just remember to get the kit that matches the block not the head or your gonna have some oil leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00nFed EM1 »</TD></TR><TR><TD CLASS="quote">s2 pro 1 prob or blox b</TD></TR></TABLE>
Uhh, I hate to be the bearer of bad news but you won't make peak power past 8.4K with those cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">
nope,but you'll have good midrange,wait the 9,000 rpm VTAK is what wins races
seriously though check all your clearances and clay the motor with those pistons,head,and cams. if you really like your peak power that high check out the jun 3's
hey mar778c check your pms i dont think they are popping up
seriously though check all your clearances and clay the motor with those pistons,head,and cams. if you really like your peak power that high check out the jun 3'shey mar778c check your pms i dont think they are popping up
that lil set actually doesnt look that bad...the acl afre 80 bucks easy alone...it bring nippon rings which arent horrible...and then has most major seals and a headgasket...i prefer oem bearings but if clearances permit nothing wrong with acl's..90% of bearing failure isnt bearing failure its user failure...not cheacking ur clearances and what not...all in all its not a bad lil set...even if u dont use the headgasket lets say...ur still getting the acl's nippon rings and alot of seals...for 112 bucks thats not bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast4imports »</TD></TR><TR><TD CLASS="quote">that lil set actually doesnt look that bad...the acl afre 80 bucks easy alone...it bring nippon rings which arent horrible...and then has most major seals and a headgasket...i prefer oem bearings but if clearances permit nothing wrong with acl's..90% of bearing failure isnt bearing failure its user failure...not cheacking ur clearances and what not...all in all its not a bad lil set...even if u dont use the headgasket lets say...ur still getting the acl's nippon rings and alot of seals...for 112 bucks thats not bad</TD></TR></TABLE>
Yea, maybe Ill just get it for the seals/gaskets and use an oem headgasket and think twice about using the acl's I guess
no reason to second guess the acl's...they are great bearings if clearance permits...just check ur clearance and if u are ok then use em...no reason not too
dravesef
Feb 12, 2008 11:29 AM
d16dcoe45
Oct 5, 2005 05:26 PM
