need some advice please ( civic 93 ,D16z6, clutch fork , ahh its a headake
to change the clutch fork on a 92 honda
civic (D16ZD) do i have to remove the starter
, un bolt the trany bolts and seprate the motor
and trany like an inch to remove the cluch fork
because , well here is whats up thers a pivit bolt
that the clutch fork teet-r-touders on it has pushed
its self almost threw the place on the cluch fork makeing
it un able to disingag the cluch so its basicly stuck in
gear i bought a new clutch fork iv already replaced
the pivit bolt once and i had to seprate the motor and
trany buy like 1-2" but i want to know is there an eazer
way? and just fyi i have an ACT clutch with a 6 puck disk
with a 46 lbs presure plate and 2ed ly do i need to undo
the pasanger side front wheel and like the botom strut
bolt i cant rember what its called basicly do i have to
remove or loosen the passanger axal to seprate the motor
and trany i did it last time but if i dont have to i wount
, i thank you for any help you can give thank you
also im loking for a digram or a how to (corectly) guide some where on line
its odd that id have to go threw like 10 hrs of labor for such an accesable part there just isant enuff room in that little hole where the clutch fork sticks out there is no wrench iv found that will unbolt the pivit bolt from on the trany im assumeing that un bolting the trany slighty is the only courst of action
jbrokos307
Mid-Atlantic (Sales)
Nov 2, 2009 07:43 AM
tepid1
Mar 6, 2007 12:29 PM
tyrub42
Jul 26, 2006 10:15 PM
