ULTRA gauge cluster
Old Feb 9, 2008 | 01:39 AM
an2ny888's Avatar
Default ULTRA gauge cluster
does anyone here have this ultra tach for the itr gauge cluster? i need some help wiring it up, it has 2 red wires, 1 black one, 1 white one and a blue one. any help would be welcome
Old Feb 9, 2008 | 02:20 AM
Kavehman's Avatar
Default Re: ULTRA gauge cluster (an2ny888)
Why would you want that ?
When you can try and make this, it's fully functional too with all warning signals and odometer.
Modified by Kavehman at 10:56 PM 2/9/2008
Old Feb 9, 2008 | 04:20 AM
Doostur's Avatar
Kavehman, picture you posted isn't showing up
Old Feb 9, 2008 | 04:39 AM
00-501itrspec's Avatar
hotttttt
Old Feb 9, 2008 | 10:20 AM
neo_'s Avatar
Default Re: ULTRA gauge cluster (00-501itrspec)
Looks like it is installed crooked, needs to move over to the left more.
Old Feb 9, 2008 | 11:20 AM
RTW DC2R's Avatar
i like it but dont see much point to having it. no instructions came with it? probably has power, ground, tach signal/distro, maybe so kind of output for shift light, not sure what else.
Old Feb 9, 2008 | 01:51 PM
pvt_awol's Avatar
Default Re: (RTW DC2R)
I'm not sure that it is my cup of tea....
But I'm not here to judge, just help. If it follows any sort of "standard" wiring, then it's like this:
Your 2 red wires are power wires. One needs to be constant, and one needs to be accessory power. Constant will be to "save" your shift light settings. Accessory of course is so the tach gets power when you start the car. Which is which, you got me. If they are different gauges, the thicker red will be your constant power.
The black will be your chassis ground.
The blue is your tach signal. You can run it from the tach signal off of your cluster, or you can run it from your distributor. On late model R's, the signal comes from the ECU, so if you run it straight from your distributor, you'll get a more accurate signal.
The white wire is your illumination. You can wire it to power to have it always be on (gay and ricey) or you can find the actual illumination wire that turns the gauge lights on when your parking lots are on. Not sure on the color off the top of my head, but that is why you should use a wire tester. Also, I'd solder in some interconnects, so that you can make a disconnectable wire harness of sorts. That way if you sell the car, change your mind on the tach, or whatever, you can just disconnect it, but everything else will still work like stock.
Old Feb 9, 2008 | 01:56 PM
Kavehman's Avatar
Picture Fixed
Old Feb 9, 2008 | 02:42 PM
98itRspec's Avatar
Default Re: ULTRA gauge cluster (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want that ?
Modified by Kavehman at 10:56 PM 2/9/2008</TD></TR></TABLE>
That's Hot!
Old Feb 9, 2008 | 02:43 PM
jeremy.'s Avatar
Default Re: (Kavehman)
Did you win that recently on Yahoo Japan?
Old Feb 9, 2008 | 05:04 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (jeremy.)
HOT *** cluster. Thought of something like this for my KAA
Old Feb 9, 2008 | 05:51 PM
RagingAngel's Avatar
Because one gauge is cheaper than 6?
Also the Ultra gauge is a stepping motor drive which makes it a lot more accurate than the stock unit.
RIGHT CLICK SAVE AS:
http://pivotjp.com/product/sg/...6.wmv
Old Feb 9, 2008 | 07:01 PM
typerman's Avatar
Default Re: ULTRA gauge cluster (RagingAngel)
Do you have a link to that ultra guage?
Old Feb 9, 2008 | 07:03 PM
RNbuilt's Avatar
Default Re: ULTRA gauge cluster (typerman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typerman &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a link to that ultra guage?</TD></TR></TABLE>
Old Feb 9, 2008 | 07:47 PM
If you're asking me... I haven't actually seen this before but would really like to get one also... you'll have to contact the OP regarding this...
Old Feb 10, 2008 | 12:51 AM
victorandolph's Avatar
i got to take off my glasses to see those big numbers.
Old Feb 10, 2008 | 10:51 AM
Numba1 K Series's Avatar
Hi!
Whoa...How much did you pay for that?
Old Feb 10, 2008 | 11:28 AM
BlueIntegraBoy's Avatar
Default Re: (pvt_awol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pvt_awol &raquo;</TD></TR><TR><TD CLASS="quote">
The white wire is your illumination. You can wire it to power to have it always be on (gay and ricey) or you can find the actual illumination wire that turns the gauge lights on when your parking lots are on. Not sure on the color off the top of my head, but that is why you should use a wire tester. Also, I'd solder in some interconnects, so that you can make a disconnectable wire harness of sorts. That way if you sell the car, change your mind on the tach, or whatever, you can just disconnect it, but everything else will still work like stock. </TD></TR></TABLE>
The color of the wire is red/black
Old Feb 10, 2008 | 03:55 PM
an2ny888's Avatar
sorry guys don't have the link to it, i searched and it appears to be out of production. am still deciding if i should install it
Old Feb 10, 2008 | 04:25 PM
flatblack-h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">sorry guys don't have the link to it, i searched and it appears to be out of production. am still deciding if i should install it</TD></TR></TABLE>
go for it
Old Feb 10, 2008 | 05:06 PM
DC209's Avatar
hey were did you buy that im very interested pls let me know
Old Feb 10, 2008 | 05:28 PM
Default Re: ULTRA gauge cluster (DC209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC209 &raquo;</TD></TR><TR><TD CLASS="quote">hey were did you buy that im very interested pls let me know</TD></TR></TABLE>
A few posts up states the tach is out of production
Old Feb 11, 2008 | 05:50 AM
an2ny888's Avatar
can anyone translate this for me? it's on one of the red wires
Old Feb 11, 2008 | 05:58 AM
Kengs's Avatar
not on their website anymore
http://www.nagaidenshi.co.jp/products.shtml
Old Feb 13, 2008 | 01:36 AM
an2ny888's Avatar
found a wiring diagram, can anyone translate?
