Hondata s100 w/ boost option
I've tried searching everywhere, and i cant find the answer... but i have the hondata s100 w/ boost option, and i was wondering what electronic boost controller would be the best to run with it, or if i even need a boost controller... please help, its a b20 w/ a peakboost topmount gt3076r and i already have the gm 3 bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slocookedrice »</TD></TR><TR><TD CLASS="quote">I've tried searching everywhere, and i cant find the answer... but i have the hondata s100 w/ boost option, and i was wondering what electronic boost controller would be the best to run with it, or if i even need a boost controller... please help, its a b20 w/ a peakboost topmount gt3076r and i already have the gm 3 bar</TD></TR></TABLE>
You can use anything from a manual boost controller to a NLR unit.
What ever suites your needs. You could also consider selling the s100 and buying s300 to use the factory ecu & a boost solenoid for boost control
alright... but i already have the s100 installed in the ecu and everything, and what is a NLR unit? and i just ordered a fuel pump, n map sensors off you guys the other night, im going to try and call you next week to answer a few questions for me! also, if i do get a boost controller, how many boost settings can the s100 have programmed, i'd preffer to have a low and high setting!
the boost option allows the ecu to see past 0vac into the boost columns only. the s100 does not have the capacity to control boost like the s300 w/ boost control option.
you may be able to use the outputs to control a staged boost controller like the ITS or the txs quad stage, i may be wrong on that though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">the boost option allows the ecu to see past 0vac into the boost columns only. the s100 does not have the capacity to control boost like the s300 w/ boost control option.
The s100 unit works with boost & non-boosted cars. There is no "boost option" for s100.
The s300 unit works with everything, however you can add ecu hardware & a boost solenoid to control boost via high/low or gear based etc.
If you don't need anything fancy, get your self a simple manual boost controller & call it done.
Few people need anything fancy.
I've seen boost per gear setups net as little as .2 in the 1/4 on a car that was running 10.6's off a two stage MBC. I've also seen boost by gear setups make a night and day difference, but only in a bigger power setup. It really depends on the car and the driver.
The average enthusiast tends to get a lot more satisfaction out of the boost by gear setups. You can clobber the gas pedal and row the shifter without worrying a lot about traction, and still be fast.
integraturbo
May 24, 2008 05:37 AM
JusT a Cx
Feb 24, 2004 05:58 PM
