'98 Accord won't go out of park
Old Feb 8, 2008 | 03:46 PM
george4's Avatar
Default '98 Accord won't go out of park
Hi, i turned on my car just now and tried to back up but the car wouldn't go out of park. I did some searching on google and it seemed to be something with the break light switch... i dont know anything about cars either so tell me if im going in the right direction.
Update: just called advanced auto parts and the guy seemed to agree that its the break light switch. Apparently its not to difficult to fix and costs $50~ to order the part. So i guess my question is should i place my order? or could it be something else?
thanks!
Old Feb 8, 2008 | 04:17 PM
hondadude's Avatar
Default Re: '98 Accord won't go out of park (george4)
Do your BRAKE lights work?
Can you hear the shift lock solenoid under the center console?
A correct and accurate diagnose is always cheaper than throwing parts at the problem.
Old Feb 8, 2008 | 05:42 PM
george4's Avatar
Default Re: '98 Accord won't go out of park (hondadude)
key part i forgot to mention that i can manually put the car into a gear by putting a key into the key shift lock and manually setting it to a gear.
Update: I just got back from the auto parts store, the break lights came back and i am able to put it into a non-park gear without using the key shift lock! Seems like the wiring is bad? Hopefully its just that unit and not else inside with some circuit!!
Old Feb 9, 2008 | 06:57 AM
erk89's Avatar
could be something as simple as a fuse, does ur horn work? cause the fuse for the horn is hte same as the one for the shift lock, try that and start from there
Old Feb 10, 2008 | 11:04 PM
tpot90's Avatar
Default Re: '98 Accord won't go out of park (erk89)
Do i have a gear shift override? There's no place for a key on the console. Or is this only for V6?
Old Feb 10, 2008 | 11:29 PM
fubuallstar's Avatar
Default Re: '98 Accord won't go out of park (tpot90)
i had same problem but instead i replaced taillights with tyc and accidentally pinched a wire. located on the driver side in the trunk under the plastics located just below taillight assembly is a little module that read resistant i burnt it quite a bit inside 2 piece of wire exposed in a u shape that had burned so i removed and replaced.
ChrissyTL
Acura TL, RL & ZDX
Nov 10, 2014 06:54 PM
XTYPES
Jul 2, 2009 04:24 PM
hometheaterman
Jan 12, 2008 08:30 PM
