Quick answer needed for shiftlinkage troubles
I need to know if I can use a '99 civic sir's shift linkage in buddy's 93 civic coupe for his turbo b16a swap? and also would the motor mounts from the '99 sir work in the '93 for the swap.
I have searched FAQ and could not find an answer...
Thanks
Thanks
I'm banking on no. You'd probably have better results with any linkage off of an Integra ('94-'01). Don't think the motor mounts will swap over either. Sorry chief.
Thanks I was'nt sure and I had doubts, saves me a 2hr trip! I think the 95 gsr linkage should work no problem though. Does any one know of any oem mounts to put a b16a into a 93 civic coupe? Or do I have to go after market?
89SiB16a
Nov 15, 2002 01:43 PM
