Quick answer needed for shiftlinkage troubles
Old 02-08-2008, 02:09 PM
Maxcapacity's Avatar
Default Quick answer needed for shiftlinkage troubles
I need to know if I can use a '99 civic sir's shift linkage in buddy's 93 civic coupe for his turbo b16a swap? and also would the motor mounts from the '99 sir work in the '93 for the swap.
I have searched FAQ and could not find an answer...
Thanks
Old 02-08-2008, 02:16 PM
hatchling37's Avatar
Default Re: Quick answer needed for shiftlinkage troubles (T- rex)
I'm banking on no. You'd probably have better results with any linkage off of an Integra ('94-'01). Don't think the motor mounts will swap over either. Sorry chief.
Old 02-08-2008, 02:27 PM
Default Re: Quick answer needed for shiftlinkage troubles (hatchling37)
Thanks I was'nt sure and I had doubts, saves me a 2hr trip! I think the 95 gsr linkage should work no problem though. Does any one know of any oem mounts to put a b16a into a 93 civic coupe? Or do I have to go after market?
Old 02-08-2008, 03:31 PM
USDMCIVICHATCH's Avatar
shift linkage and axles will work 100%!!!! sure
mounts or brackets will not work 100%!!! sure
Youlose1305
07-05-2006 04:23 PM
NoFiA
09-22-2004 08:35 PM
civhatchsi
03-13-2003 07:40 PM
89SiB16a
11-15-2002 01:43 PM
wickedEFguy
08-21-2002 02:59 PM
Quick Reply: Quick answer needed for shiftlinkage troubles
