Suspension & Brakes Theory, alignment, spring rates....
Info on Password JDM rear trail arm setup????
Old Feb 8, 2008 | 10:07 AM
punksz6's Avatar
Default Info on Password JDM rear trail arm setup????
I need to replace my rear trailing arm bushing and noticed that Password JDM had new rear trailing arm setup. since i have to replace mine does anyone think that i should invest in these or is it not worth it???? my car is a 93 EJ1 with x3 racing adj coilovers on tokico blues, dumped have front and rear camber kits. Need info?? thanks new to this site!!!
Old Feb 8, 2008 | 10:22 AM
.:Made in OC:.'s Avatar
Default Re: Info on Password JDM rear trail arm setup???? (punksz6)
Is it a race car or a street driven car? If its street driven i would suggest going with Energy Suspension Poly replacements, Hardrace hardened rubber, or Mugen bushings. Those should be more then enough to compensate for the rear end wiggle at high speeds. If your never going to hit the track you probably wont feel rear end wiggle such as if you were at a track taking a corner at 90mph. If you go spherical its going to be a bit more harsh on the streets and probably will need to be replaced more often.
Old Feb 8, 2008 | 10:38 AM
punksz6's Avatar
Default Re: Info on Password JDM rear trail arm setup???? (.:Made in OC:.)
yeah its a street driven Ej. Thanks for the info. Still don't know it could become a track car but for now i guess i'll go with the other bushings thanks again!!
Old Feb 10, 2008 | 11:57 AM
egsleepercivic's Avatar
just replace with oem rear trailing arm bushing unless its a dedicated race car, stay away from the poly
slowteg97
Suspension & Brakes
10
Feb 7, 2008 12:45 AM
litterbox
21
Feb 16, 2005 10:07 AM
Tweakmeister
26
Jan 4, 2005 01:17 PM
bulldog_RS20
Aug 13, 2002 12:45 PM
albert butterbikini
Sep 21, 2001 02:18 PM
